20 Most Recent
ASUS (GENEIRC DRW-1608P BLACK) (GENEIRCDRW1608PBLACK) DVD Drive Questions & Answers
How do i open the cd drive?
There is a tiny hole on the face of the drawer that has the logo in it. You can straighten a paper clip and push it in and then push a little harder and the drawer will open.
Hello, My problem is that
you might have to physically unplug the plug you cd rom back in this should activate the found new harware wizard or you might try
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
I just got this computer
No doubt that it reading it as mass storage device. Its probably not getting power to the drive or its a DoA drive. send it back and get it replaced.
My dvd-rw from my new laptop asus k50c not working
Windows XP
- Click Start, and then click Run.
- In the Open box, type regedit, and then click OK.
- In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
- In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
- On the Edit menu, click Delete.
- When you are prompted to confirm the deletion, click Yes.
- In the right pane, click LowerFilters.
Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
- Exit Registry Editor.
- Restart the computer.
Hi, my asus drw-20B1LT has suddenly stopped
Try this:
Open Registry editor (Start > Run > (Type regedit and press enter)
Open the following key (You will have to keep on clicking several keys to get to this starting with HKEY_CURRENT_USER)
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
Double click 'NoDriveTypeAutoRun' key on right and set the value to 'b9'
Close registry editor, restart and try.
Dvd not open any dvd
the laser has gone inside the drive... it will be much cheaper to buy a new one :)
thanks
alex
DVD problem
Let me figure out that problem, that usually happen when there is miss align of your dvd drive, that cannot read the optic in your dvd when you insert any disc. Have it check with repair man or technician.
Widows setup failure..
Greetings
It is not the cd that has a problem, its your hardisk if you have other hardisk try to exchange it and re-install your computer. or format your computer with other comupter.
Thanks
Cannor Read DVDs
I have a similar issue to you, except that my dvd drive will only recognize a disc if I have booted up into windows with it in the tray...once in windows it will still think it has the first disc in no matter what disc i insert. If i boot up with no disc then it will never read it unless I follow the steps below.
A solution I found by pure frustration and trying all sorts of things is to eject the DVD tray and leave it opened, then right click on the dvd drive in 'my computer' and select the 'hardware' tab...then select the drive and click 'properties'.
A new window should open. Select 'volumes' and click 'populate'. Now close the window and insert the disc you wish to read, close the tray and repeat this process. Windows should now recognize the disc you inserted
Alot of trouble I know, but it works for me. Hope this helps.
ASUS DRW-1608p35
Odd considering video uses more bandwidth and cache than photos....how much ram is in your computer, and where are th ephotos youre attempting to copy?
