20 Most Recent
ASUS SiS Chipset CUSI-FX Motherboard Questions & Answers
Acpi x86 pc
Your GTX 650 requires 450w MINIMUM to run.I highly recommend you get a 550w+ power supply to ensure it runs stable.There is an 80% likelihood you simply do not have the power to run this video card.10% the card is faulty.10% someone else is going wrong.Open up your case and check how much power your power supply has.
Windows sp3 was installed on
first right click my computer clickproperties then click hardware then device manager and in the click sound vedio and came controller and see wether the driver is installed properly if you see question mark in the driver or the driver not installed properly reload your sound driver which came with the motherboard if the drivers are installed properly then click start settings control pannel then click sound and audio device then click volume and move the slider to high then untick the mute button if ticked then restart the computer
Keyboard problem
Hi there please explain me more. I guess the problem is keyboard not working properly. If it is then i suggest you please reinstall the keyboard driver again & try. I hope your problem will solve then. Thanks.
Regarding upgradation of SDRAM
hi dear
there is always speed mismatch problem occur when we use low processor & high ram
so try to use 256 ram
also try to use 1 slot of 256 ram & 2 slots of 128 ram diffrently
& compare the speed
hope it will help to u
Updated BIOS fail
to have your problem solved you will have to send the mobo to the manufacturer so that they can flash it and put back the original
Drivers
I have lost my motherboard driver cd.how I can get the sound driver software.motherboard companyname:asus
model:cusi-fx
revision:1009
version:V1.0A
Up-date processor.
Check the manual for jumper settings on the cpu frontsidebus frequency. Also find out your cpus fsb or frontside bus speed and match it with the motherboards jumpers if possible.
How to find out details of the processor?
Pentium III 1ghz - download cpuz www.google.com cpuz download
it will tell you more details of the cpu. If you post here a image of the cpuz screen or all the details it shows you can I tell you the correct fsb speed.
Then you need to find your motherboards manual and the part about those jumpers. and set them correctly.
Bios Stuck
sounds like a thermal issue, check your coolers.
remember if you are trying this after running your system for an hour, the heat sinks may be hot. be careful not to burn yourself
if your CPU gets to hot your system will freeze like this, also once it gets this hot it will freeze in the bios too.
