20 Most Recent
ASUS P4C800 Deluxe Motherboard Questions & Answers
Bios Will not recognize my
first have you UPDATED the bios??? the mother board might not support 1TB hard drive with the present firmware...
Connecting to internet
first you must have an ISP Internet Service provider which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the net or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts
hope this helps
Just install XP PRO sp3 on P4C800 board and
When your using Internet connection via LAN you need to configure the Internet Protocol (TCP/IP) Properties at the Network Connection Wizard. To configure the Network Connection just follow this steps:
1. Double click the My Computer from your desktop/screen.
2. At the left side of the My Computer menu click the My Network Places then click View Network Connections in the left side of that window also.
3. Double click the Local Area Connection and click Properties.
4. When the Local Area Connection Properties was appear select Internet Protocol (TCP/IP) then click Properties.
5. The Internet Protocol (TCP/IP) Properties are also apear, then click Use the following IP address and fill-up the following: IP Address, Subnet Mask, Default Gateway, Preferred DNS Server and Alternate DNS Server.
6. After all you fill-up click OK Button.
Note: Make sure that the IP Address you fill-up in your network connection are not the same with the other computer to avoid conflict. Just copy the configuration on the computer like: Subnet Mask, Default Gateway, Preferred DNS Server and Alternate DNS Server. Only the IP Address are unique to the other computer. Example; 192.168.0.5 that is the IP Address of last computer are connected in the network. The IP Address you able to use is 192.168.0.6, only the last digit of the IP Address your going to change.
SATA Drivers
at ysytem start up you need to acces your biose window f1 or f12 or escape or del
are comen keys to try in borem window of system at first trun on it shold tell you the key to press to acsess you biose system setup window.
after you acess this goto hard drive setup slect stst as your hard drive then your system is ready to setup.
thanks.
daniel
Motherboard
ASUSTeK Computer Inc.-Support- - 3:07pmEnglish. 繁體中文. 简体中文. 日本語. Español. Português. 한국어. Русский. Français. Deutsch. Česky. Polski. Brasil. Latinoamericano
...support.asus.com/faq/faq.aspx - 46k -
Cached - Similar pages -GO HERE CLICK ON THIS URL (1ST ONE)ENTER P4C800 DELUXE. IN THE SEARCH BOX.COMPLETE DRIVERS MANUALS ETC. ONE NICE NEET PLACE.THOSE GUYS AT ASUS ARE GREAT.RICHARDM69
No Sound
it may look fine, but i think there is some trouble with the installation of motherboard on the new case take a review on it.
it happened to me before.I just reinstall it to the new nase and chechk for any lose connection or any busted chips. in that case try some new motherboard
No boot or bios or display at turn on.
I had exactly the same problem with my kids PC last week, also an Asus on an AMD flatform. I reset the BIOS and clean install the OS and now its working fine. You have to reformat the harddisk, cause in my case it doesn't show its exact capacity when I it hooked it up as slave drive with my own PC. Maybe a virus did it.
Wires they connect two 2 pins on motherboard
Do you have the manual of the motherboard, please mention the type, make, model, manufacturer of motherboard please this way we can help you out. Also please try to mention your question clearly.
Thanks
