20 Most Recent Altec Lansing Multimedia Computer Speakers Questions & Answers
I have a set of stereo computer speakers, Altec
i did the same thing when i was over seas, damn 220v, and all it did was blow the fuse in the unit, if you have an inline fuse (along the power cord) it might have blown there, if not you will have to take the unit apart and change the fuse, might be soldiered on the circuit board but its a relatively easy fix, just hope that the board itself didnt get shorted out, if so you will need to replace the system, i used this website when i was overseas and all my stuff got to me with in 10 days...
www.newegg.com
3/4/2020 12:51:55 PM • Altec Lansing... • Answered on Mar 04, 2020
2answers
Altec Lansing ada745
Oh, my goodness.  I have the exact same problem, and it just happened to me today as well, same model.  The fifth prong got bent in while I was trying to plug it back in after diagnosing a different issue (speaker volume would randomly jump up and down regardless of audio source).
It looks like a PS/2 style connector with one of the top pins missing, so I thought about taking an old PS/2 plug and grafting it on after breaking off one of those pins, but the center plastic block on the PS/2 connector is unfortunately keyed differently than the speaker plug (it's lower down on the PS/2 plug).
3/6/2019 6:41:25 PM • Altec Lansing... • Answered on Mar 06, 2019
0answers
Altec Lansing Multimedia ACS5 computer speakers quit working after installing Windows Update and recommended installations!
Use system restore to a point when the speakers were working. Then take it from there.
11/12/2017 6:09:28 PM • Altec Lansing... • Answered on Nov 12, 2017
0answers
Mono
Be the first to answer 10/25/2017 1:12:06 PM • Altec Lansing... • Posted on Oct 25, 2017Be the first to answer
3answers
Altec Lansing ada745 fuse
It is written on the sub. You can also take it out or look at the spare which is taped to the power cord wall plug. I believe it's T1A 250V fuse
6/20/2017 1:39:11 AM • Altec Lansing... • Answered on Jun 20, 2017
NO Sound from NEW speaker unit?
Yes the green wire that goes from the speaker should be plugged into the green jack on the PC. An easy test to see if its the computer or the speakers is to have the speakers on and volume up a little and tap the tip of the green plug with your fingers while out of the computer. If it makes a humming or any noise at all while tapping, the speakers are working if not lets check voltage at the power plug or if the unit has any lights on. Gook luck!
4/24/2017 8:59:48 PM • Altec Lansing... • Answered on Apr 24, 2017
0answers
11answers
Finding replacement Power Supply for Altec Lansing
Hi Yeo... Amazon offers pretty much power supply products, click on this link Finally charging for our multi device world and choose your model. I hope this was helpful. enjoy
11/19/2014 4:18:28 AM • Altec Lansing... • Answered on Nov 19, 2014
How it is possible to use laptop charger for computer speakers?
ya it is possible if the support of in put of the speaker and out put of the charger is same then you can use it
6/4/2014 7:33:27 AM • Altec Lansing... • Answered on Jun 04, 2014
Altec lansing acs33
the subwoofer plugs into the wall on a 110 volt outlet. then use mastervolume control.. RANDY
4/28/2014 8:17:07 PM • Altec Lansing... • Answered on Apr 28, 2014
Static coming from speakers
Not much information here but I will try my best, could be a problem with the cable your using between the speakers and the mp3 player, you could have a dry joint, if it's like a "hum" sound your getting it's a bad ground, without the mp3 playing plugged in tap the end of the stereo minijack cable with the speakers turned up? hear the 50hz buzz - if the interference sounds the same it's most likely a bad cable or bad connector on the speakers. I would need to either hear the interference to determine what fault it is or if you can describe it better i.e. what it sounds like.
4/3/2014 12:56:17 PM • Altec Lansing... • Answered on Apr 03, 2014
2answers
Broken speaker
the only way is o replace the wires from end to end.. you may have to do some soldering inside the subwoofer and the satellite speakers
1/9/2014 4:24:32 AM • Altec Lansing... • Answered on Jan 09, 2014
0answers
180 questions posted
Top Altec Lansing Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
 Grubhead
Grubhead
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Altec Lansing Audio Players & Recorders
Most Popular Question
finding replacement power supply altec
  • Audio Players & Recorders
