Altec Lansing ACS 22 Computer... • Uploaded on Mar 06, 2019
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets is usually at the back of the computer or if it's a laptop on the side you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good with no dust as dust causes static electricity clean your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
11 questions posted
117 Questions
73 Questions
69 Questions
61 Questions
44 Questions
