20 Most Recent
Canon BubbleJet i550 InkJet Printer Questions & Answers
Canon i550 yellow light blinks 7 times.
You machine probably thinks it has more than one of the same colour installed. Take them all out and re-install one at a time allowing the machine to reset between each . If it doesn't fix the problem you will find out which cartridge is at fault and replace it.
Canon i560 Ink jet Error Code 5C00
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
I've just acquired a 2nd
Here is a possible solution.
Open 'Printers and Faxes' and right-click your printer. Select 'Properties' from the menu.
Select Paper/Quality tab. And from the 'Paper Source' select 'Auto feeder' or 'Auto' if 'Manual feed' is selected.
If Manual feed is selected, that means the printer is waiting for you to insert a paper for each page to print. That is why you get only the first page printed.
Good luck! And if this solves your problem, consider voting me.
Thanks for using FixYa!
My i550 won't print
When I
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Wanted to download printer driver canon i55
Hi There and Welcome to Fixya.
Please visit the link I provided below for you to download the i550 printer driver:
Printer DriverAll you have to do is choose the operating system that you use then click on the file driver that will come out. After that, just "Agree" with the terms and start downloading the driver.
After completing the download, start the driver installation and follow the on screen prompts until it finishes - Restart your computer when the installation is done.
Hope this helps, Thanks for using Fixya.
Canon i550-turn on-orange/green 8x then long green
From the Canon website:
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Ink Absorber Replacement Options i550
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
For the Waste Tank Reset Code, and how to repair or replace the Waste Tank, see this website:
http://www.bioscomputers.ca/CanonWasteTankCodes.htm
Canon i550 LED error sequence: 7 orange +1 green flash
According to Canon 7 orange flashes indicates a print head fault. Solution they recommend is to take it to one of their service agents. Problem is that replacement print heads are not cheap and it is usually more economical to replace the printer. You could try taking the print head to a cartridge refiller and have it professionally cleaned (cost you nothing or next to nothing) and see if that solves the problem.
