20 Most Recent
Canon ImageClass MF5770 Laser Copier Printer Fax Scanner Network Questions & Answers
How can you check the page counter on the MF5770
If there is a LCD panel on the front there will be a maintenance mode for you printer if you find out which key presses you need to enter it then you will find the page count plus other info like no. of cartridges, you might have to go to a 3rd party dealer who specializes in printer repair as most companies like canon and brother can get hold of the service PDF's.
Lines when scanned
The common solution on this sight to this problem on any copier seemed to be simply clean the glass. I first cleaned the glass on the bed...no help. Then I lifted the feeder and discovered a portion of the glass under that as well. Once it was cleaned the lines disappeared!
I saved $$ on a useless service call for a simple, easy to fix problem thanks to this site!
E000 sYSTEM eRROR
Solution:
Unplug unit for 3-5 minutes, then plug the unit back in
Unplug unit for 3-5 minutes, then plug the unit back in.
OR
I hope it helps!!!
Re Canon MF 5770, copies are too light, even when
This happens when the fuser is not reaching operating temperature, it is not getting hot enough.
The laser printer's fuser assembly is the most common component to cause problems and require repair. Paper dust and residual toner can accumulate, causing scratches on the roller, which creates unwanted marks on the print. Conversely, large scratches will allow areas of toner not to bake into the sheet. In these cases, the toner smears off the page after it comes out of the printer.
Additionally, the lamp can burn out and require replacement, and the thermostat can also fail and need to be replaced. Read more:
What Is a Laser Printer Fuser? ' eHow.com http://www.ehow.com/about_5122756_laser-printer-fuser.html#ixzz1CLr9InQr
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
