20 Most Recent
Canon PIXMA MP750 All-In-One InkJet Printer Questions & Answers
My canon MP250 displays error P08
Turn power off. Press and hold the Stop/Reset button. Press and hold the ON button. Release the Stop/Reset button. Press the Stop/Reset button twice and release the ON button (now you should not be pressing any buttons). Wait for the printer to cycle. Turn it off and back on.
Just set up the printer and ran a test print.
the printer head is clogged with dry ink inside the channels and need to be dissolved.Remove all 5 cartridges you will see 5 inputs roundish mesh strainer correspond to the 5 colors and. put few drops of isopropyl alcohol in each you will see the ink waste coming from the print head nozzle. clean the head nicely with tissues and wait until dry. go to printer maintenance and click on deep clean...... i hope will do.
nabil
MP750 Printer does not power on. There were no
1-check the power cable if it is twisted from both sides. or buy new power be sure it is inserted nicely into the printer socke.t
2- check the plug if there is any fuse! if it is blown up., change the fuse with the same amp rate.
3-check power source socket...try another power source wall socket.
4-keep long press on the power on.
I hope will do....otherwise something went wrong with your internal power supply good luck.
How do i clean the printhead on my pixma mp750
If you open the preferences option for your printer there should be a maintenance tab with easy options for cleaning and checking the results.
The alternative is to use the menu directly on the printer:
1. Press Menu twice to show "2. Maintenance"
2. The first option is NOZZLE CHECK
3. Press OK
This should give you a print showing the current state of each colour. If there are any missing lines in 3eBK or lines in any colours then perform the head cleaning below.
2. Press + to show "CLEANING"
3. Press OK
Repeat the nozzle check after each clean. If not improved after three attempts try a deep clean as below (cleaning uses up ink)
2. Press + twice to show "HEAD REFRESHING"
3. Press OK
Repeat the nozzle check. If still not printing correctly there are various external solutions available to clean the print head such as http://www.printheadhospital.co.uk/canon-hp-printhead-cleaning-kit.html
Wrong cartridge
If the cartridge you bought is not compatible with that prescribed by the printer, the interconnecting ends may not match. You, therefore, need to change all wrong cartridges.
Scanning picture to facebook
Try going to devices list on your computer, select the canon icon, right click and select scan from menu.next, the scanner window will open ,start scan, save scanned item to your documents or desktop (somewhere easy to find) .open your Facebook profile, choose photos, and then upload from the file location where you saved the scanned item.
Page not printing on Canon PIXMA MP750
That's as common as rocks with inkjets, especially if Copy doesn't produce visible output. Fortunately the clean cycle gets results pretty often. You need to heed the printer humidity spec. and follow the manual's further actions for when 'Clean Head' doesn't work (typically cleaning its bedding and/or running some rubbing alcohol through via a handy empty cartridge.) See your local ink refiller if you want a friend to lean on for cleaning cartridge fiddling.
I have a Canon Pixma MP750 and I am getting that
the waste ink is collected in a box because of cleaning of the cartridge take place on power on and before printing. simply you have to despose off the ink. try to take out that box by opening front cover. if you do not access that box u have to open top, back and side covers.
Copying
Maybe you pushed the small button on the left "two sided"...I did and got the same reading...I pushed it again to return. I think that is what happened...
