20 Most Recent Canon CanoScan N1240U Flatbed Scanner Questions & Answers
2answers
Need Twain driver for windows 7 for canon Scan
The TWAIN drive should be installed when one installs the actual "Drivers" for the unit itself, accordingly I provide you with the download link below.... look for and install ALL drivers and software, especially the Scan manager and TWAIN drivers....
http://usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_n1240u
4/23/2014 2:58:05 PM • Canon CanoScan... • Answered on Apr 23, 2014
Install driver
Klaus Kartelmeyer
12/13/2013 4:26:16 PM • Canon CanoScan... • Answered on Dec 13, 2013
3answers
Need driver for canoscan N124OU for windows 7
Alternative driver download link: Canon CanoScan N1240U Scanner Driver
8/28/2012 9:09:25 PM • Canon CanoScan... • Answered on Aug 28, 2012
2answers
CANNOT INSTAL CANON n1240U SCANNER
Your scanner model is not supported on windows 7.
8/8/2011 1:53:44 PM • Canon CanoScan... • Answered on Aug 08, 2011
2answers
I dont have the cd
Click here
Click on above link select os and download driver and install.
Let me know if you need further assistance.
thanks for using FixYa.
8/4/2011 5:23:02 PM • Canon CanoScan... • Answered on Aug 04, 2011
I download XP driver for
scan with adob photoshop /import - from - your scaner device/ , it will be correctly, maybe toolbox not working normally, if with photoshop will not be resaults, in control panel \ in scaner and imaging devices see is there your scanner, if it will not be in there, reinstall driver.
6/1/2011 9:32:59 PM • Canon CanoScan... • Answered on Jun 01, 2011
I have windows 7 and
Canon has no driver for CanoScan N1240U on its website for Windows 7. But, if you want to try with the one for Windows Vista, you can find it here: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_n1240u#DriversAndSoftware
4/16/2011 4:34:32 PM • Canon CanoScan... • Answered on Apr 16, 2011
CANNOT INSTALL ON WINDOWS 7
I have many years repairing Canon Scanners so maybe I can help you.
I assume you are running Windows 7 because of how you worded your question. I went to Canon's website to see what drivers were available for you there. The closest thing they have is Vista drivers which may or may not work for you. But its worth a try to install them they are close to Window 7 drivers. Try and install them this way.
First unplug the cable from you scanner to your computer.
Second go here http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_n1240u#DriversAndSoftware
(copy this whole line into your web browser or click on it to see if it will take you there) Then download the drivers from Canons website and install them. On install it will tell you that the drivers are not digitally signed for your operating system do you still want to install them just say YES and complete the install.
Third once the drivers install it may ask you to plug in your scanner (make sure your scanner is powered on and ready to use) then plug it in. If at the end of the driver install it doesn't ask you to plug in your scanner then just plug it in but make sure it is powered on and ready to use.
Fourth A window may pop up after you plug in your scanner to your computer and it should say a new device or drivers are being installed. Once this completes its install I want you to reboot (restart) your computer. Once your computer comes back up after the reboot you should be able to scan.
If this does not work as I described it to you then contact canon either by phone or email and ask for drivers for Windows 7 or even beta drivers if they even have those available yet.
I hope this helps you out and if it does please give me a YES that you were helped. Thank you.
4/5/2011 10:31:16 PM • Canon CanoScan... • Answered on Apr 05, 2011
HOW CAN I CANNOT INSTALL MY CANOSCAN 12400 OU ON
This is very easy to do all you will need is the drivers to install your scanner with. Here is the link to get the drivers you need.
Scroll through the menu to select the scanner drivers you need. Before you install these drivers unplug the scanner from your computer. Then download and install the drivers. Turn your scanner on so it is powered up, plug the scanner back into the computer. A window will popup saying a new device or drivers are being installed. Once that completes its process reboot (restart) your computer and you now can scan from your computer.
I hope this helps you out, if it does please leave me some feedback.
4/4/2011 4:07:28 PM • Canon CanoScan... • Answered on Apr 04, 2011
I NEED TO INSTALL MY CANOSCAN N124OU ONTO MY
go to this site: http://support-th.canon-asia.com/P/search?model=CanoScan+N1240U&menu=download&filter=0&tagname=g_os&g_os=Windows%20Vista
However, i dont think it is compatible with windows 7.
4/4/2011 2:10:39 PM • Canon CanoScan... • Answered on Apr 04, 2011
I need CanoScan n1240 driver
I have many years repairing Canon scanners so here is my suggestion to you.
I would google the model scanner you have Canoscan n 12540 with driver on the end. It will take you to canon's website. Download the latest drivers they are free, and you may want to download capture perfect too because that is also free and it will help you with your scanning of documents or pictures.
I hope this helps you out.
4/1/2011 2:52:34 AM • Canon CanoScan... • Answered on Apr 01, 2011
Scanner not printing as states insufficient memor
I have many years of experience repairing canon scanners so here is my suggestion to you.
Your problem is a common one with all scanners, they use a lot of memory to process the images your scanning in to your computer. My suggestion is to up grade your memory if you can, preferably to at least 512mb then you have now but preferably to 1 gig. Then you will be able to scan anything you want to.
4/1/2011 2:35:55 AM • Canon CanoScan... • Answered on Apr 01, 2011
Is Canoscan N1240U compatible with Mac OS?
Some folks in the apple discussion forums got it working with 10.6: http://discussions.apple.com/thread.jspa?threadID=2263035
Includes link to drivers: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6621
3/21/2011 4:38:08 PM • Canon CanoScan... • Answered on Mar 21, 2011
I can not use Canoscan
Have you tried the Vista drivers on the Canon website? http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_n1240u#DriversAndSoftware
You'd pick Windows Vista in the Select OS dropdown.
3/2/2011 7:43:05 AM • Canon CanoScan... • Answered on Mar 02, 2011
How do i open the scanner to change the lamp?
This is a very nice scanner - however, I think you will find it cheaper (and much easier) to buy a new one and forget about trying to repair it.
2/9/2011 4:38:19 PM • Canon CanoScan... • Answered on Feb 09, 2011
Canon CanoScan N1240U Flatbed Scanner Logo
Popular Tags
69 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
CanoScan Canon
  • CanoScan Canon
Most Popular Question
need driver canoscan n124ou windows 7
  • Office Equipment & Supplies
