20 Most Recent Zanussi ZDF490 Electric Double Oven Questions & Answers
0answers
Do you have to pull the full oven out to replace the grill element on a Zanussi ZDF490
you usually have to remove a couple screws from the back panel to get to the element and in others u can remove it from within if u look inside u should be able to see if it has a screw holding it. and the connecting plugs can be removed from the element
3/11/2015 9:44:26 PM • Zanussi ZDF490... • Answered on Mar 11, 2015
0answers
I have a Zamussi ZUQ875 double oven. I have just replaced the bottom oven element after it went bang. Nothing tripped out but the digital display has gone out and cannot get main oven to work because
i suspect that you did cut power to the oven when you replaced the element. therefore the oven needs to be reset as new. there are quite a few pages of instructions on setting the timer so be prepared if you are going to to proceed with this "little" project.I was able to locate your manual online here:http://kitchen.manualsonline.com/manuals/mfg/zanussi/zuq_875.html?idRes=625295 I suggest unplugging it for a few minutes...then plugging it back in. Hopefully if the electrical is good you will see the oven's timer flashing. then you can proceed with the instructions from page 7.Otherwise, you may have a blown a short and should get a licensed electrician to look at it.Another option would be to contact the manufacturer:[email protected], find the bloke that installed it and invite him over for dinner and maybe he'll notice it's not working and will fix it for free! ;-)Good luck mate!
2/23/2012 2:33:09 PM • Zanussi ZDF490... • Answered on Feb 23, 2012
0answers
How do i take
check out this
6/18/2011 11:36:20 AM • Zanussi ZDF490... • Answered on Jun 18, 2011
Not heating
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
4/11/2011 7:14:38 PM • Zanussi ZDF490... • Answered on Apr 11, 2011
I have a ZDF20X double oven and the main bottom
Most likely it is a faulty oven heating element.
You will need to replace the element.
Usually the element is a circular shape which is situated near the fan, normally you will need to remove the back of the oven, Switch off the power at the wall first, locate the element and remove the fixing screws and electrical connections then fit the new element and reconnect.
Only attempt this replacement if you are confident to do so and have a basic electrical and mechanical knowledge.
12/11/2010 2:01:57 PM • Zanussi ZDF490... • Answered on Dec 11, 2010
Lower oven not heating up
check if supply at element conections if not oven control prob burnt out if supply at element conections elements prob burnt out hope its the elements its the most comon fault
10/3/2010 11:09:25 AM • Zanussi ZDF490... • Answered on Oct 03, 2010
Lights flashing ovens will not work
good day,
hope this link below will solve your problem.
ovens
8/2/2010 4:39:19 AM • Zanussi ZDF490... • Answered on Aug 02, 2010
Oven fan wont stop when oven has completely
You should have someone come and look at it.
7/18/2010 9:28:21 AM • Zanussi ZDF490... • Answered on Jul 18, 2010
Main oven has stopped heating up
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
4/26/2010 2:50:37 AM • Zanussi ZDF490... • Answered on Apr 26, 2010
THE FAN IS WORKING ON THE MAIN OVEN BUT NO HEAT
For all Free appliance repair videos visit our VIDEO TUTORIALS
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
1/14/2010 6:47:09 PM • Zanussi ZDF490... • Answered on Jan 14, 2010
Zanussi ZDF490 Electric Double Oven Logo
30 questions posted
Top Zanussi Ovens Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
View Most Popular
Zanussi Ovens
  • Zanussi Ovens
Most Popular Question
lower oven not heating up
  • Ovens
