20 Most Recent Honda Ex-800 Portable Gasoline Generator 800 Watt Output, Old Stock Ex Questions & Answers
You need to change the small thing that lets fuel flow into the carb... "turn fuel off and on gauge" do u understand GetMonthlyPay com Get Your Guranteed Home Job for 1500 weekly ?
Honda Ex-800... | Answered on Jan 14, 2014
Your compressor is made by Hitachi. The pilot valve is what controls the engine and the pressure. Most likely the pilot is set to idle engine at 125 psi. The pilot valve can be adjusted higher or lower depending on needs but not higher than say 140. As the pressure drops to about 80 psi the pilot will cut in the engine to refill the tank. Pilot and throttle controls are finicky and require constant tinkering and or parts replacement. Your compressor needs the pilot to control pressure however does not need the throttle control. You can set the engine on constant speed. Less trouble but uses little more gas. Just remove the throttle control from the pilot and plug the hole. If the bad part is the pilot itself you will need to replace it. The new pilot will be adjusted to about 125 psi. Good luck with your repair
Honda Air Tools... | Answered on Aug 27, 2019
Not worth the work. Just leave it disconnected and check oil twice daily under hard working conditions. Change the oil every 100 hrs of hard use or when it looks black and dirty.
Honda Air Tools... | Answered on Apr 17, 2014
Hi
Look at all associated couplings on the delivery side of the receiver to ensure that air passing through
every joint/coupling and that the hose has not got collapsed walls that are compounded by air pressure.
A good tester to make up is to get 2 hose joiner ends, fit to an either a galv.or brass nipple, join together and test that there is a good flow of air from all points of delivery
Hope this helps
Cheers
John
Honda Air Tools... | Answered on Jul 22, 2011
Honda Ex-800 Portable Gasoline Generator 800 Watt Output, Old Stock Ex Logo
6 questions posted
Top Honda Air Tools & Compressors Experts
John Trevino
Marvin
Marvin
Lawrence Oravetz
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Honda Air Tools & Compressors
Most Popular Question
honda ex 800 fuel filter in gas tank
  • Air Tools & Compressors
