20 Most Recent
Compaq (CDD480172) CD-RW Burner Questions & Answers
Will not open
It's time for a qualified repairman to check into it.
7/6/2014 6:10:22 AM •
Compaq...
Answered
on Jul 06, 2014
I put cd in and
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. oryou might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
6/25/2011 2:19:24 AM •
Compaq...
Answered
on Jun 25, 2011
My cd/dvd burner driver is
Sounds like the drive likely died or became disconnected within the laptop. Since it is a laptop you should take it into a compaq service provider and ask them to replace or repair it, it will likely be cheap and fairly easy. I wouldn't recommend doing it yourself however, unless you are familiar with the innards of a laptop. Hope this helps, good luck.
3/15/2011 11:52:19 PM •
Compaq...
Answered
on Mar 15, 2011
CD/DVD burner in Compaq Presario
Microsoft updates may not have the driver you are looking when it is searching for drivers. When you are in the device manager make a quick note to the name of the device and go to
http://www.compaq.com/country/cpq_support.html
and see if you can match the device to the driver for your pc. If you are able to find the correct driver and install it and still receive the same results then the drive itself may have a problem.
3/14/2011 3:53:35 PM •
Compaq...
Answered
on Mar 14, 2011
Ok so my compaq presario windows xp home edition
make sure that the cd burner is getting enough power test all leads that are attached to the cd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
1/3/2011 1:07:06 AM •
Compaq...
Answered
on Jan 03, 2011
The DVD tray doesnt eject
either it is the ribbon wire, the motor that ejects the tray or the belt that connect the tray and motor is the problem. In case the above three are fine, replace the drive as the sparking might kill your moterboard.
7/8/2009 1:08:59 PM •
Compaq...
Answered
on Jul 08, 2009
Compaq presario SR1903WM SERIES
you may need to check to see if you have a CD writeble Rom, open up the computer to see if the cd rom cord is in all the way. I would put a DVD rewriteable in the computer new ones come with the software. you may need a driver.
www.download.com
you may only have a CD rom, and you need a CD writer to burn songs. A DVD writer can burn CD's and DVD's
4/29/2009 4:27:19 PM •
Compaq...
Answered
on Apr 29, 2009
CD Burning
Hi you can obtain a cd cleaning disk insert and follow instructions as the most common fault is dirt on the lens. If you do not get a cleaning disk open the cd draw and with a soft brush clean the little lens and then test. If this doesn't work check that the cd has rotated by placing one in the draw close wait 2-3 seconds and open see if the cd has turned. If it hasn't replace drive
Thanks J
8/16/2008 6:35:31 PM •
Compaq...
Answered
on Aug 16, 2008
Cd tray won't open
their is an tiny hole in the cd tray.. f their is... u insert a pin that cn fit to it you estimate the pin head is... while pushing the eject button
6/6/2008 7:51:20 PM •
Compaq...
Answered
on Jun 06, 2008
Doesnt read it
Clean the lens normally the cause of you fault after that reinstall the drivers for it.
Thanks J
2/6/2008 11:09:00 AM •
Compaq...
Answered
on Feb 06, 2008
