20 Most Recent
Craftsman 33 Gallon Vertical Portable Air Compressor Questions & Answers
Compressor will not come on, and it is tripping my breaker
THIS IS ALL I COULD FIND ON THE INTERNET NOT SURE IF ITS GOING TO BE OF ANY HELP TO YOU.
Do you have any other electrical appliance in the circuit that might cycle on when the compressor is starting? If there isn't enough current to go around, that might be an issue.
it could be a failing pressure switch.
Check your unloader valve. I think that it has failed, and as a result, the motor can't overcome the additional load on start up.
If the compressor is blowing the breaker, you know that it's either a short of some kind, or the electrical motor is pulling more amps than the circuit can handle..
If you are sure that it's not a short, and the motor actually starts (it's not the capacitor), and the motor shaft turns easily (meaning that the power train into the compressor head is not binding in some way and overloading the motor) then it's got to be the motor that's at fault.
Try this. Unplug the compressor, drain the tank all the way down to no PSI on the gauge, close the tank drain, and plug it back in / start the compressor.
Does it start?
I suspect either you are overheating your compressor to the point where it starts to seize (thus drawing more amps and popping the breaker) or you've already damaged the motor and it's cycle gets shorter and shorter before it's overheated to the point of seizing.
OR TRY THIS LINK.
air compressor starts then trips breaker Google Search
I have the 919.167320 and it keeps tripping the
There is a voltage drop, excessive voltage drop in the circuit.
Anything else on that circuit?
Is the circuit wire size #12 awg thru the complete circuit to the outlet?
Any extension cords being used?
Voltage drop is found in high amperage loads. A motor needs about six times the motors rated full load amps value. Drops found in long runs of wire, in loose connections, in smaller Gage wire than needed.
The power outlet in the garage for the compressor may need the next size wire, #10 AWG. Try using a circuit breaker rated for air conditioning use, they have a trip delay.
It does not start at all. What should I look for?
Check for power. Check the on/off switch for power. Check the motor reset button if it is tripped, push it in. Check the pressure switch for power, check if the pressure switch makes contact if there is power.
