20 Most Recent Baumatic 18 in. BFD46 Free-standing Dishwasher Questions & Answers
Won't fill with water
Hello & Welcome to FixYa
Dishwasher not filling problem is caused by clogged inlet valve, first try to clean the inlet valve and the water line coming to the inlet valve. If the issue returns replacing the water inlet valve is recommended repair. Please get back to me if you have any other questions.
Kevin
12/20/2011 3:22:13 PM • Baumatic 18 in.... • Answered on Dec 20, 2011
I have a baumatic mini4 tabletop dishwasher and
As there are a couple of troubleshooting for this leak. As with out doing it is not easy to understand whether its a plumbing issue or the washer is not draining constantly in cycles.
http://www.ehow.com/how_5004047_fix-frigidaire-dishwasher-leaking-water.html
Thanks
6/2/2010 3:37:45 PM • Baumatic 18 in.... • Answered on Jun 02, 2010
The soap dispenser on my bosch dishwasher doesn't open
it is agood manual solution but if you want to rea ly fix that there is {an electrical order reach at suitable time to open the dispenser it come from electronic circuit to elecronic lock which catch the
dispenser so one of those parts may be fualty
6/9/2009 10:35:36 PM • Baumatic 18 in.... • Answered on Jun 09, 2009
Cycle will not start
sounds like your machine is not taking in any water at all, which is the first thing the dishwasher wants to do on all programme settings.The constant whirring noise you refer to will be the water valve trying to take water into your machine.As yours isn't filling in the first place the programme cannot progress without water and it will just sit there whirring.Anyway, to resolve this matter I would check the fill hose which goes from the back of machine to your cold water pipe in your kitchen/utility, in case somebody has turned off supply.where the flexi hose meets the copper supply pipe there should be a thumbturn shut/open valve, turn this 90 degrees or a quarter turn and if you here a rush of water for a split second then you have fixed it.At this point try setting away a programme to see if water is going into dishwasher. If not have a bucket ready and unscrew the flexi hose altogether to make sure water is travelling past shut/open valve.If not you need a new shut/open valve.If water is able to pass this valve reconnect to dishwasher turn shut/open valve a quarter turn to open flow of water again,test machine on any programme again ,if it fills then your sorted, if not it must be your dishwashers internal water valve that will need replacing.Not a major job (located behind fill hose) but make sure electric and water supplies are off first before dabbling and write down your machines make and model number before shopping for part. GOOD LUCK.
8/15/2007 1:41:04 AM • Baumatic 18 in.... • Answered on Aug 15, 2007
Hi, I have a baumatic dishwasher BBM14S. It is stuck on a emptying cycle but it was empty. I poured water in 3L but has not made a difference. It is only under 2 years old. Richard
It does not matter how old it is. Our dish washer broke after two months. I'd suggest calling I a tech person to take a look at it.
2/14/2019 5:46:16 PM • Baumatic... • Answered on Feb 14, 2019
0answers
Baumatic 18 in. BFD46 Free-standing Dishwasher Logo
14 questions posted
Top Baumatic Dishwashers Experts
Mike Cairns
Mike Cairns
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Baumatic Dishwashers
Most Popular Question
fill water
  • Dishwashers
