20 Most Recent
Baumatic 24 in. BFD60SS Free-standing Dishwasher Questions & Answers
Baumatic BFD60SS - Tablet not dissolving
this happened with mine and it turned out that the top shelf was too low, so this meant the spinning arm was being stopped by my plates. When the machine is fully loaded check that the spinners can move freely. if they don't then you can move the top shelf up a level. hope this helps
Shows err 4 on display screen, turn on and just
Hi.
E4 is overfill. This dishwasher has overvill protection.
Disconnect power and remove water from the inside using bucket and sponge. If problem occurrs frequently call service, the overflow protect device may need replacement. Service number is listed on manual.
To remove water use sponge and bucket. Ensure that power is off. On some model you need to remove the fascia panel at the base of the dishwasher, on front side. Use a screwdriver to remove panel; on others you dry water only from inside the tub
Dishwasher keeps running
The dishwasher should heat the water to about 50 C as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water and waiting for the water to reach the temperature. In your case it look like the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues.
Another possible is that the timer unit is defective (this is the worse case because of its cost !!!!)
Baumatic BHD 5
Is the water draining out of the machine? if not does it drain when you lower the pipe to the floor, if it does you need a new pump, if it doesn't you have a blockage.
Dishwasher
Most dishwashers have a little filter basket in the bottom. Depending on the brand, you can slide out the bottom rack, and in the bottom underneath the sprayer (the propeller thing) there should be some sort of basket that can be removed and cleaned. You also may have some water quality issues, or some detergents will leave residue. Also, make sure most of the large food is removed before loading.
