20 Most Recent
Baumatic 23 in. BDW9 Built-in Dishwasher Questions & Answers
My left hand side door cord has broken, how much
Yes you will have to move from under worktop and then remove the side panel that the cord has broken.It may be worth checking the other cord and replacing both if worn.Also check if something is catching to cause the cord to break.
Hope this helped.
My Baumatic bdw9 dishwasher's door is leaking from
- open the bottom panel 2-4 screw
- take a flashlight and turn the machine on
- see where it come from
- if you need take the unit out a bit from the counter
- check it all around to find the sorce of the leak
- good luck its EZ :)
Right hand side nylon spring cord guide broken
Searched for a nylon rope guide for a Baumatic BDW 9 but was unable to locate one. I found that many of the components for the BDW 9 also fitted the BDW 10. So I searched for the rope guide for a BDW 10 and found the correct product. Problem solved!
Baumatic DW9
Hi - You can download the manual by clicking the link underlined in blue below:
Baumatic DW9Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Baumatic dishwasher BDW9
This looks to be the same problem I'm having with my dishwasher (BDW15) I have removed the control panel and have noticed the On Off button has started to burn out, thus cuasing intermitant power supply.
Solution is to replace the On Off switch with a new one, which I'm still drying to source as it's Christmas and everybody is shut.
Hope this helps
Craig...
