20 Most Recent
Baumatic 23 in. BDW5 Built-in Dishwasher Questions & Answers
Top tray wheels keep falling off
I feel for you! I have been tortured by the blasted wheels falling off every time I go to put something into the dishwasher, or want to empty it. To add to it all, this part is no longer available to replace, which I need to do as one of the clips finally snapped off. It is a highly frustrating design flaw in this machine.
Flashing lights beeping
The dishwasher has too much water in it, this is a safety feature.
Underneath is a tray at the bottom, you need to empty this before it will start again. I've had this problem many times. My dishwasher had tiny holes in the bottom tray where the basket sits, went rusty due to not using it very often (holiday home). dried it out, applied silicon sealant to the edge where the metal sits, let it dry and the problem was solved.
I have used a sucking water vacuum to remove water, or tipped it forward. Hope this helps for maybe next time.
Baumatic b15 drain pump will not stop.
Sounds like a dicky or jammed water level sensor. Get a qualified and licensed technician to check it out. The sensor and labour to replace it should only be around AU$50 or AU$60 dollars (excluding callout or pickup / delivery fees).
My dishwasher runs through the
Unfortunately it is important that the dishes are rinsed before they are placed into the dishwasher as the primary job is to get your dishes sterilized and cleaned.
So please try and remote off as much of particles by showing the dishes to the wash tap or use a wiper to clean off the food particles.
In all machines there are drains to which the drain pump is fitted and there is a filter but if the dirt level is too much the filter and also the drain pump will be clogged.
You can remove the pump and back-flush using a good spray, clean the filter by removing and flushing with brushing.
Once this is cleaned the pump must work and drain the waste water.
All the lights come on but the machine does not wash
The problem could be 1) The inlet solinoid in line with the main water inlet faulty this acts as an electrical tap controling the inlet water. 2) The triggering of the anti flood system (polysireene float and micro switch at the base of washer) due to water leak / spill (this device causes the washer to stop until the leak is cleared.3) Water pressure to low.
