20 Most Recent
Baumatic MEGA6SS Front Load Washer Questions & Answers
My baumatic bk6el wont drain sin drain
Drain the machine , drain hose next to drank plug , undo the drain plug and make sure there is nothing stopping the propeller turns using a torch to see with , if all turns and nothing lodged there then it's your pump ps easy job to do and cheap to repair your self , if you need more information get back to me colin evans
Clear error code Baumatic BFLW75
When the appliance displays an error code even after the faulty components have been replaced follow the instructions bellow
Turn the program selector to "off"
Turn the Program selector once to either the left or the right
Error code is now displayed in the window
Press "Spin Speed" once
Press "Function" once
Depending on the last status of the machine the door may lock!
You are now in the test program!
Press "Water level" until t 0 2 is displayed in the window
Press "Start Pause" once to show "ELE" then "Start Pause"
again to display the last error code.
Turn the program selector to off, the machines memory is now cleared and the programmer will start again as normal.
What does e33 mean on a baumatic washing machine
not saying this is whats wrong with it i just found this on the internet............hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
