20 Most Recent
Compaq (252608-001) Motherboard Questions & Answers
Why did my display disappear?
Possible electrolict capacitor defeated. Replace is needed.
I suggest make a electronic tech consulting. Good Luck !
8/15/2014 4:56:37 PM •
Compaq...
Answered
on Aug 15, 2014
Hi can I add 2G ram for this mother board
Yes. When the manual was created 1GB pc133 sdram modules weren't available yet, but they said when they did come out that the bios would support them so the max ram you can have is 3GB.
Here is an excerpt from the manual: System Memory Type/Speed SDRAM DIMM - PC133 Only Current Maximum Memory 1.5-GB Maximum Memory 3-GB (when 1-GB PC133 SDRAM are available) Memory Parity Not Supported ECC Memory Supported (Intel 845 chipset does not support mixing of Non-ECC and ECC PC133 memory)
Here is the manual:http://h18000.www1.hp.com/products/quickspecs/10946_div/10946_div.HTML
8/22/2012 6:14:38 PM •
Compaq...
Answered
on Aug 22, 2012
Hi, I have cleaned my
If you dont have the motherboards manual, then post a more detailed photo.
Connectors are to the bottom right of the motherboard when you fit her to the PC case, try to take a closer pic of them and post again.
7/18/2011 7:57:47 AM •
Compaq...
Answered
on Jul 18, 2011
My old smps has gone
to check smps you need to short the green and block wire using a paper clicp if the fan is iworking the problem is not with your smps
12/30/2010 3:37:10 PM •
Compaq...
Answered
on Dec 30, 2010
I need Compaq 07e4h drivers?
Not sure if this is what you are looking for check it out and read through and make sure it's what yyou are looking for.
http://www.kukulska.nieruchomosci.pl/compaq-07e4h
11/30/2010 2:21:00 PM •
Compaq...
Answered
on Nov 30, 2010
No sound
Hi paramban, try going to the "Control Panel from the Start Menu, open and choose Hardware and Sound" or the Device Manager, open and find; the Sound, select the "Playback" button, on your operating system the categories may differ in wording, but find your Speakers to Update the Drivers" "Thanks for using Fix' Ya, and please give a rating if the solution helped!"
10/23/2010 4:21:51 PM •
Compaq...
Answered
on Oct 23, 2010
How can i check my mother board model
You'd have to open up the case (carefully) and take a look at the motherboard itself.
Above the horizontally stacked white slots, there will be another of a different type. If it's long and colored, it's likely PCI-Ex16/2.0. If it's medium-length and colored, it's likely AGP. If there is no such slot, you'll just have to use PCI video-cards.
Thanks & waiting for your feedback.
2/6/2010 10:10:32 AM •
Compaq...
Answered
on Feb 06, 2010
