20 Most Recent Baldor RM3120 HVAC Fan and Blower Motor, ODP, Resilient Base , 56H Frame, Three Phase 1 1/2 HP, 3600 RPM Questions & Answers
"Can't get it apart from wiring." Makes no sense.
No question.
Baldor RM3120... | Answered on Jan 24, 2015
It is simple to wire a Delta To Y or Y To Delta connection specially if your motor has a junction box. Also see for reference.
https://ph.images.search.yahoo.com/search/images;_ylt=A2oKmL0X0dRTpFEA9bizRwx.?p=3+phase+y+and+delta+connection&fr=yfp-t-711&fr2=piv-web
Baldor RM3120... | Answered on Jul 27, 2014
Some motors need a Y and Delta, with a special switch, to start up, you start with the Y. the motor starts turning, but does not give full power. after a few seconds (depends what the manual says) you switch to delta, to get full power. To let it run on full power in Y you need 1,4 times the voltage.
If everything runs fine, you won't have damaged anything.
Baldor RM3120... | Answered on Jul 13, 2014
Delta is entirely different connection.... look here:
https://www.google.co.uk/search?q=3+Phase+Motor&es_sm=122&tbm=isch&tbo=u&source=univ&sa=X&ei=TWKZU9jpJobSOe3lgdAD&ved=0CEMQsAQ&biw=1534&bih=846
Baldor RM3120... | Answered on Jun 12, 2014
A three phase motor in an Audi? Really? Try Cars and Trucks.
Baldor RM3120... | Answered on Oct 07, 2012
Need more information make of faucets so forth
Plumbing | Answered Yesterday
You can try at http://www.ps2i.biz here you can get all professional plumbing services at very reasonable price.
Plumbing | Answered 2 days ago
Leaking from the stem or handle 90% of the time means all you need is a new cartridge or new O rings or seals, depending on the model of your faucet.
Phister has a warranty https://www.pfisterfaucets.com/parts-support/warranty-information
and if they are like other faucet manufacturers with a similar warranty, just take the bad part(s) to your local authorized Pfister dealer and they will exchange them over the counter. Otherwise, you can contact Pfister through their website.
Plumbing | Answered on Oct 30, 2019
There are a lot of variables. Are you on a shallow well pump? It sounds like the well doesn't make much water. Check your well tank pressure. With 0 psi of water (drain the pressure) There should be 2 psi of air less than than the start up. If the pump is set to start at 30 psi, there should be 28 psi of air in the tank. It sounds to me like either the tank is shot, or the pump doesn't make much water. If you leave a faucet on while putting air in the tank and air comes out the faucet, then, the bladder is shot.
Baldor RM3120 HVAC Fan and Blower Motor, ODP, Resilient Base , 56H Frame, Three Phase 1 1/2 HP, 3600 RPM Logo
13 questions posted
Top Baldor Plumbing Experts
Donni Steen
Tom Chichester
Are you a Baldor Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Baldor Plumbing
  • Baldor Plumbing
Most Popular Question
run 3 phase motor y or star connection
  • Plumbing
