20 Most Recent
Labtec LCS 1030 Computer Speakers Questions & Answers
I had windows xp with
Try this one
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
I need a new power supply for Labtec LCS 1030
I know this is a little late, but the power supply that these speakers use appears to be 5mm across. The output specifications are 15V DC, 1000mAh (1A), with the center pin being negative.
Right side speaker will not
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Opening Labtec speakers type LCS-1030
To open these you need to pull the front grille off. There are four screws, one in each corner. You'll need to do a bit of prying to get it open as the case is sealed around the edges, but it isn't too terribly difficult. Just take your time.
Driver download
These are speakers and do not require drivers. Your computer's sound card does require drivers, though.
I have no power supply cord for my labtec lcs-1030
On the back of one of the speakers, there will be 3 plugs; a green one, a grey one, and a black one. The black one is the power plug. Right below the power plug it says the voltage needed (I could only find one picture online, and it looks like it says 15v, which would be 15 volts). That number is the needed supply voltage, so search google for (number under plug) volt power adapter.
My pc does not regonise
Good day. In response to your issue, you might need to reinstall the driver for your speakers this will correct any problem on your audio if it encounter any error and just restart the computer to finalize the installation.
Note: some software can cause conflicts with other software better check the compatability of every device or software that you plan on installing on your computer. You can check the guide or manual for this informations
Hope this help you a bit. Have a great day and thanks for choosing Fixya.
Think I fried the lcs 1030 main speaker board.
If you can get the speakers open, check for blown capacitors or puffy capacitors. If you see any they will need to be replaced with capacitors with the same UF rating and at least the same voltage and make sure you line up the striped line with the striped line of the motherboard. You'll need to be able to undsolder and solder the caps off and on.
If you see big black marks on the board then the board is basically usueless cause it would cost more to fix then the cost of the board itself. Also check for any blown fuses and if there is you would need to replace them with the same rating.
What's the part number for the operational amplifier ,DC 15dc of LCS 1024
why not photo the IC, and show that.
for 10x better answers.
not told what car is came out of or what the OBJECT did. (PCM/ECU/BCM ,etc?) <<< vast on cars/trucks\
many PCB or Modules the ICs are some or all , contract parts
and the number on top is secret contract Part number.
ahhhhhh it is not a CAR at all it is
LABTEC LCS-1024 AMPLIFIED COMPUTER SPEAKERS
moving you now to computers stuff
Can you hook up a Labtec 2424 sub to a smart TV
If you are looking for the top security companies in London that provides its customer with remarkable security services. Check out this site for security services https://www.urbansecurityguards.co.uk
