20 Most Recent Compaq Athlon XP 2000+ , 1.67 GHz Processor Upgrade Questions & Answers
hi, from your reference i could get the info that your pc is running with the mainboard similar to FIC - am37,and with that the below mentioned processors are supported. Recommended Speeds: AMD Athlon? XP 2600+ (266 FSB) AMD Athlon? XP 2400+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2400+ (266 FSB) AMD Athlon? XP 2200+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2200+ (266 FSB) AMD Athlon? XP 2100+ (266 FSB) Model 8 AMD Athlon? XP 2100+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 8 AMD Athlon? XP 2000+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 10 w/ 256K Cache all the best.. sreejith
Compaq Athlon XP... | Answered on Dec 02, 2019
use wired Ethernet, so it works. easy.
wifi is far more complex.
best is to own the router, you have.
then login to it and set it up for wpa./wpa2
wep off.
and a nice password for wifi so others cant hack it. in the hood.
then use those credentials all all your toys. xbox, PCs and cell.
that is the best way
the access point is covered in you manual for the router
there is AP button there, you push.
the PC in question my guess is the drivers are no good.
missing wrong, or corrupted.
no PC full model stated.
no OS stated
no router stated.
so answers will be weak to wrong,.
Compaq Computers... | Answered 2 days ago
Start your web browser,
find options, open options.
Find and open search.
On this page you will see
"Use the address bar for search and navigation"
and
"Add search bar in toolbar"
which puts a separate window next to the address bar with search written in it..
Choose which one you want to use
Go down to one click search engines.
You will see a number of search engines in a box usually ticked.
I use a search engine called Duckduckgo because it does not keep any data on me...
under the search engines box there is a line in blue "Find more search engines".
Click on the blue line and you will see a list of different search engines, click on one and a new page will open up and you follow instructions to install the search engine.
In she search engine box, if you do not want use one of engines just un-tick it
Hope this helps
Regards
Geoff
Compaq Computers... | Answered on Jan 11, 2020
b> Copy-protected DVDs prohibit people from copying them, which is piracy. Copying a DVD to sell or even to give away is illegal. You can play copy-protected DVDs in a standalone DVD player or in your computer's DVD drive, as long as your computer's software is up to date. These DVDs will play the same as DVDs that are not copy protected
Press the "Eject" button on your DVD player to open the DVD tray. Set the DVD into the tray, and push the "Eject" button to close the tray. Press the "Play" button on your DVD player, and the DVD will play. b> On a DVD Drive on a Computer Press the "Eject" button on your DVD drive to eject the DVD tray. Set the DVD into the DVD drive, and push the tray in to close it. Click the "Start" tab on your computer's home screen to open the "Start" menu. Click on "My Computer" to open it. Click on the DVD drive to open the DVD. Click on "Autoplay" to play the DVD.
Compaq Computers... | Answered on Jan 06, 2020
Google
make model manual
They are all online. It _may_ be an eject button
Replace the CMOS (Complementary Metal-Oxide Semiconductor) battery to ... Turn off and unplug the netbook before replacing the battery. ... Press both orange eject buttons simultaneously, and use a spudger to pry off the back case. .... Tablet · Phone · Laptop · Repairable Products · E-waste · Recycling · Manufacturing ..
Compaq Computers... | Answered on Dec 26, 2019
Check this:
http://diy-ksoft.com/arduino/578-28-inch-tft-lcd-touch-screen-module-uno-expansion-board-for-arduino.html?search_query=LCD+arduino&results=114
There are a lot of touchscreens for arduino. Also if you want to keep it firmware compatible with what you have, you need to know the model and the interface type for it to get a new one that yill match yours.
Without further details is not possible to help you more....
Regards,
L. Coelho
Compaq Computers... | Answered on Dec 20, 2019
You stated an issue about playing/viewing AVI files on your computer?
I would suggest to go ahead and download an AVI file converter(w/c you can search via google or download via Filehippo.com)or get an AVI viewer/Player
(e.g. VLC etc./can also be searched/downloaded via gooogle.com or FileHippo.com)
Hope This Helps.
Thanks,
FixerDelta
Compaq Computers... | Answered on Nov 20, 2019
A dvd burner will burn anything you tell it to burn, the things is you need certain programs to see what the extension was that you burnt.
EX- if you burn a DIVX file, windows media player won't see it, but it will see a WMP file.
The most important thing is the burning software, makes it easy to burn boot, ISO files, video.
But like I said, a DVD burner will burn anything you tell it to burn.
Compaq Computers... | Answered on Nov 06, 2019
You must have got a disc having samsung kies,which is a pc suite for samsung mobile phones.If not click here to download pc suite for your phone.This link will take you to samsung support for GT-S3310.
Compaq Computers... | Answered on Sep 19, 2019
There are a number of reasons why a computer will bluescreen. You'll likely need to take the unit in to a qualified technician to get it fixed.
Compaq Computers... | Answered on Aug 29, 2019
let me guess lost the PC it came with>????? other shoe drops.?
let me guess need use those custom keys and don't know how.
well you need that PC it was sold with.
lost?
this, even HP and Google can't find it, why mess with PCs this old? with PS2 cable end, why use that? and it will not work on non Compaq PC as PS2 is unique to each maker.
no PC even told just found in a garage sale, for 10cents.
Compaq Computers... | Answered on Aug 25, 2019
you lost the case to it, it was , or buy ***** motherboard?
- Compaq Presario SR5130NX !!! 12 years old I think. 2007
what are you doing , ?
why need any RS232 COM1 port or relic LPT 25pin port
can you tell why first? and this does not exist here.
(sure with add-in cards or USB dongles on any PC)
that PC is old, Compaq ran for many years and HP killed it 2013. ONLY HP.com support it today, ok?
I see you reading the mobo numbers top center
desktop OLD. and top CPU is.
Core 2 Duo E4x00 with Dual Core technology (Conroe) up to E4400
relic.
2GB max ram. total.
gma950. no intel support now.
why think this card mobo has COM1 port, there is none
nor LPT line printer port, for years.
HP ended support on the PC long ago.
all they have is , echo of past , light.
https://support.hp.com/us-en/document/c01048297?jumpid=reg_r1002_usen_c-001_title_r0001
Most wireless keyboards come with a little device that you insert in one of the USB ports on your PC. Here is a web site that describe this method, and a couple other types of wireless keyboards.
https://www.wikihow.com/Connect-Wireless-Keyboard-to-PC
Compaq Computers... | Answered on Aug 16, 2019
Click on the link below and download VLC media player >>>>>>>
http://www.videolan.org/vlc/
Try load the AVI in that. If it still won't play then you have wasted your time downloading a fake file.
A good idea is to read any comments left on the torrent site you use before you download any files.
Regards.
Compaq Computers... | Answered on Jul 17, 2019
57-100 57-200, 57-300 or 400? there are 4 versions.
to what device? unstated and matters big time. BT head phones?
first is , it must have Bluetooth, most didn't then.
it was an option, then. (in fact many options)
most times its part of the wifi card inside.(and was)
or it did work before today (I lost)? means that?
then the HP Compaq driver is missing for it.
HP has it , if you download it.
the #1 cause of Bluetooth software driver failure is upgrading the unstated OS and there is no driver for that OS. (w7 to 10?)
what OS does your 57 run?
it came with windows 7, is that it?
the 57-100 PC has this driver.(Wild guess, no PC full P/N stated)
worse yet they offered 2 BT cards seen here(network drivers)
(what I do , lacking hwINFO32.exe is look at the card first.
see what is there. make and model. the pick the driver.
https://support.hp.com/us-en/drivers/selfservice/compaq-presario-cq57-100-notebook-pc-series/5059083
Compaq Computers... | Answered on Jul 15, 2019
Depending upon where you live in the world, this may be perfectly legal...
On the other hand, you might have no recourse, but to buy another copy.
Might I suggest ebay ?
Compaq Computers... | Answered on Jun 26, 2019
plz try by reinstalling the ethernet driver, if the problem is not solved then check with a working lan cable.if your ethernet card is working with another lan cable then your ethernet card is faulty other wise your cable is faulty.
Compaq Computers... | Answered on Jun 05, 2019
Compaq Athlon XP 2000+ , 1.67 GHz Processor Upgrade Logo
1 questions posted
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Computers & Internet
Most Popular Question
processor
  • Computers & Internet
