20 Most Recent
Labtec Spin 70 Computer Speakers Questions & Answers
I have some Labtec speakers
According to the specs your speakers are intended to use a standard 3.5 mm stereo headphone jack. I doubt your new Macbook will not be equipped with such a jack socket and so if they don't work when plugged into the headphone jack of the Macbook but do work in the headphone jack of the PC it is clearly the fault of the Macbook - maybe the socket is faulty or hasn't been enabled or something.
Sorry but I know nothing about Macintosh other than I hear they are almost entirely interchangeable with Windows these days. If they don't have a headphone socket it would seem they are actually inferior rather than the superiority they claim.
Cannot get a sound from the speakers
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
WHAT IS THE MAUFATURING WEBSITE
Go to Google.com then type on Labtec Spin 70 Computer Speakers and you will find all the info you need on your speakers if that is what you mean in your question?
I have Labtec 1070 speakers... they work fine on
In case you have a drivers' problem you need the drivers for your soundcard (Dell motherboard). So please clarify me your Dell model.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Labtec speakers want play
check whether the output plug is connected properly or not.... if it is then check out whether the adapter is giving the power output.... if it is then the speakers are spoilt otherwise u can just replace the adapter...
No sound
just reinstall the sound drivers from the manufacture web-site and reinstall it
Labtec 1070 speaker wire is shot
It looks like this wire is not replaceable. The good news is you can get another pair of these exact speakers for 8.99 us. here is a link for that :
http://www.mypcbee.com/cat1186.html
What's the part number for the operational amplifier ,DC 15dc of LCS 1024
why not photo the IC, and show that.
for 10x better answers.
not told what car is came out of or what the OBJECT did. (PCM/ECU/BCM ,etc?) <<< vast on cars/trucks\
many PCB or Modules the ICs are some or all , contract parts
and the number on top is secret contract Part number.
ahhhhhh it is not a CAR at all it is
LABTEC LCS-1024 AMPLIFIED COMPUTER SPEAKERS
moving you now to computers stuff
Can you hook up a Labtec 2424 sub to a smart TV
If you are looking for the top security companies in London that provides its customer with remarkable security services. Check out this site for security services https://www.urbansecurityguards.co.uk
