20 Most Recent Baumatic BWE40 Wine Cooler Questions & Answers
BWE40 wine cooler. Is it safe to leave it switched on when code e2 is showing? Does code e2 distinguish which of the two sensors need replacing? Thanks.
e2 is a temperature sensor error code. You would need a multimeter to test sensor and control board. Either could be the problem
5/22/2017 10:36:09 AM • Baumatic BWE40... • Answered on May 22, 2017
0answers
0answers
Hello, I have BW40 wine
There are 2 sensors in this wine cooler. Malfunction of each leads to E1 or E2 fault codes. One is easily accessible inside the fridge (small white torpedo sensor with pair of wires attached). The second but identical sensor is buried within the foam on the rear of the cooler. Unplug from mains, take of the electrics from back of cooler, take off sheet metal back and the sensor will be deep in the foam and can be replaced easily after digging out some foam. When replaced make sure the sensor is in the same place it stops the cooler icing up. Use gap-fill foam to keep insulation good. Dr_Nicholas
5/10/2014 4:07:57 PM • Baumatic BWE40... • Answered on May 10, 2014
0answers
0answers
0answers
0answers
E2 Error
Be the first to answer 6/23/2013 5:56:08 PM • Baumatic BWE40... • Posted on Jun 23, 2013Be the first to answer
It wont cool, stays at 17 deg
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Be sure the BACK COVER is in place and hasnt been accidently removed.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
9/27/2011 8:41:35 PM • Baumatic BWE40... • Answered on Sep 27, 2011
Baumatic BWE40 Wine Cooler Logo
34 questions posted
Top Baumatic Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Baumatic Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Baumatic Refrigerators
Most Popular Question
bw40 wine
  • Refrigerators
