20 Most Recent McCulloch 11 HP 5700 WATT GENERATOR Questions & Answers
Where do I find a fuel switch/valve mine has broke off 5700 11 hp
We sell them!.... http://www.generatorguru.com/fuel-tap-petcock-24902290/ And many other Mcculloch Generator Parts and Spares: http://www.generatorguru.com/mcculloch Need more advice? Contact us, we are always happy to help! http://www.generatorguru.com/ask-the-guru/ Regards The Generator Guru Team
10/15/2016 9:56:08 AM • McCulloch 11 HP... • Answered on Oct 15, 2016
Need a schematic of the carburetor
If you go to the McCuloch website or go to the dealer you bought it from they will email you or print one off for you on site.
5/12/2016 11:29:30 PM • McCulloch 11 HP... • Answered on May 12, 2016
How can I replace carburetor?
I believe the electric solenoid is a fuel shut off. solenoid needs energized, normally with switch 12 Volts. other then float bowls are the carbs. identical, if they are switch bowls, should work. If not you will have to add switched power to solenoid, the link below looked similar to yours. Generac Generator Carb removal and disassembly McCulloch Generator Model FG5700AK
1/25/2016 9:12:12 PM • McCulloch 11 HP... • Answered on Jan 25, 2016
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
1/21/2016 12:38:40 AM • McCulloch 11 HP... • Answered on Jan 21, 2016
What oil does it use
Give us a call when you are with the Generator and we will run through it with you. Call your local office and speak to an engineer: http://www.generatorguru.com/ask-the-guru/ Generator Guru
9/25/2015 11:30:56 AM • McCulloch 11 HP... • Answered on Sep 25, 2015
0answers
Low voltage
You have overloaded the generator and have blown a capacitor, resistor or similar item that will only allow half the voltage output to the recepticals. I know I have done this too.
12/6/2013 5:48:55 AM • McCulloch 11 HP... • Answered on Dec 06, 2013
Generator will crank but will not start
First check spark while cranking over( pull the plug wire hold by insulator about a 1/4 inch away from any ground, you should see a strong spark. then check to be sure the fuel is pumping from yhe carb., if no fuel try a short squirt into the carb intake. should fire up if you had spark.Its generally a good idea to put in a new plug and be sure to check the gap.
10/1/2013 12:54:58 AM • McCulloch 11 HP... • Answered on Oct 01, 2013
McCulloch 11 HP 5700 WATT GENERATOR Logo
28 questions posted
Top McCulloch Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • McCulloch Electrical Supplies
Most Popular Question
find fuel switch valve mine broke off
  • Electrical Supplies
