20 Most Recent
D-Link DSL 302G (DSL-302G) Modem Questions & Answers
Hello Sir I m frm India n I have this modem.The
Hi Piyush,
Have you tried changing MTU settings in your modem?
Try that,that can solve your problem.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
No power
cain9:
If I am not mistaken I think you used the power adapter from 302g to 502t?, if yes try simply using the adapter that came with 502t, also please try any other power source from wall socket and try replacing your power bar. If nothing comes up then it could be hardware failure.
I had the same issue with my Dlink router but that was simply the power surge that effected my Dlink router as being continous ON.
I recommend to start using power surge they add a little cost but are really big time savers for things which have to stay ON.
Hope that helped!
All of a sudden when
If your modem is connected to the router with a USB cord insread ofan ethernet cord you can only use one pc
Hope it helps
D-LINK DSL 302 G modem connectvity problem
* Visit support.dlink.com
- Make sure that you choose the right product on the site
- Download the Configuration Utility 1.00 for your D-LINK DSL 302 G modem
- Install to the computer then just follow the instructions
*Sorry it doesn't have the emulator to follow the directions.
I want to connect my
Sorry,your hardware only support Windows 98SE, Me, 2K, XP, or Mac OS 9 and OS X,so you may not be able to connect it in windows 7.
But the manufacturer has done some revised on the driver
here is the link of that revised driver
ftp://ftp.dlink.com/Broadband/dsl302g_revC/Drivers/dsl302G_driver_103.zip
check it out
MMX 610U Airtel USB does not support Windows Vista
I have Windows Vista. my Airtel MMX 610 U USB modem does not identify SIM and does not work. Also it is well working with Windows other versions like server, or 2000.
please provide me solution or patch for Windows Vista
thanks
Vinod
Modem keeps disconnecting and needs rebooting every time I use it
Yes, this can be a problem with the modem that you have first thing that you need to do here is to reset the modem and reconfigure it back, but if after that still have the same problem better contact your ISP and ask them if everything is working from their end...
Hope that helps...............
Driver Wanted for D - Link dsl - 302 G
http://www.opendrivers.com/freedownload/214628/d-link-dsl-302g-revision-c-usb-driver-1.03-windows-98-me-2000-xp-download.html
http://www.opendrivers.com/driver/214628/d-link-dsl-302g-revision-c-usb-driver-1.03-windows-98-me-2000-xp-free-download.html
scroll down that page.. you will find your driver software
