20 Most Recent Dell 2 Button Mouse 6u226 Questions & Answers
Dell mouse scroll wheel spring repair
The scroll wheels on these units have a plastic pin, if the pin is broken, it may not hold in place properly and droop, so you cannot spin the wheel. These mouse are no longer made. Replacement mouse can be found on Amazon and eBay for very little cost. The model you have posted has a PS/2 connector. There are still other mouse that are made with the PS/2 connector, if you need it.
1/3/2020 6:58:00 PM • Dell 2 Button... • Answered on Jan 03, 2020
We use the software "Leprechaun"
Buy a new mouse, let pc find and install software,should solve issue
11/8/2018 12:17:42 PM • Dell 2 Button... • Answered on Nov 08, 2018
Can't scroll through folder with many files using Win Explorer
replace the batterys in the mouse and keyboard
9/17/2018 1:36:11 AM • Dell 2 Button... • Answered on Sep 17, 2018
Switching mouse and keyboard
It is very easy buy usb keyboard and mouse and use it it is plug and play.
9/13/2017 12:12:50 PM • Dell 2 Button... • Answered on Sep 13, 2017
I don't know how to
With the older ps2 mouse like the one in your picture what usually goes wrong with them is the ball on the bottom gets dirty. Disconnect the mouse from your computer when your computer is turned off. Flip the mouse over and you will see a grey rubber ball in the center. On the outer edges is a black ring. That ring can be removed by turning it counter clock wise and once removed the ball will fall out in to your hand when you tip the mouse back over. Take the ball to your kitchen sink and wash it really good with warm soap and water. Then dry it off with a rag making sure that there is no dirt left on the ball rub it hard to make sure all the dirt is removed. Then flip your mouse over so the opening is facing up at you. Place the ring back in place and lock it down by turning it clock wise until it wont move anymore. This should get your mouse back to moving correctly around your screen. Plug it back in to your computer turn your computer back on again and test the mouse to see if it scrolls correctly across the screen again.
If the buttons are no longer working when you use them to click on something then my suggestion is purchase a new mouse. You can find a PS2 style mouse on Ebay they have a ton of those for sale and they are very cheap to purchase today.
I hope this helps you out.
4/1/2011 9:33:25 PM • Dell 2 Button... • Answered on Apr 01, 2011
My dell mouse (I'm not
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers click start control panel administration tool computer managenent device manager scroll to mice and other pointing devices you might see a yellow question mark? right click to update drivers make sure the lead from the mouse has a secure seating and the lead is not bad/faulty (if applicable) make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable) click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot in xp hope this helps dont forget to vote
2/26/2011 11:20:54 PM • Dell 2 Button... • Answered on Feb 26, 2011
My mouse cant go left
may be problem in control penal
just folow the step
XP windows
1 go to control penal
2 mouse settings
3 Buttons
chack there your mouse is selected
Right-hand boton if it then it will work
4/12/2010 3:22:14 AM • Dell 2 Button... • Answered on Apr 12, 2010
It keeps stalling and shiffting to the right
Sounds like the contacts are dirty. If it has a ball underneath, remove cover and ball then clean the little wheels (contacts) inside.
3/6/2010 4:51:22 PM • Dell 2 Button... • Answered on Mar 06, 2010
5answers
Dell 2-button mouse
2/25/2010 1:51:21 PM • Dell 2 Button... • Answered on Feb 25, 2010
When I right click it double clicks. For example,
The transmitting IC inside your mouse, mouse are cheap now a days, it's better to buy new one than have it repair which will cause you more than buying a new one
11/8/2009 8:58:26 PM • Dell 2 Button... • Answered on Nov 08, 2009
2answers
The usb ports will not work,therefore the mouse
Try the mouse in a computer where the USB ports *DO* work.
It is possible that your system does not have the correct "device-drivers" for the USB ports. Thus, those USB ports seem to be "dead".
Turn the computer off.
Connect a PS/2 keyboard and a PS/2 mouse.
Turn the computer on.
Click START
Click Control Panel
Click System
Click Hardware
Click Device Manager
Expand the "USB ports" section of the tree.
Look for "yellow" or "red" marks.
Double-click one of those "problem" devices.
Choose "Reinstall Driver".
If it asks to be able to connect to the Internet, click "yes, this time".
Hopefully, this will install the correct drivers for your USB ports.
11/6/2009 7:20:20 AM • Dell 2 Button... • Answered on Nov 06, 2009
Large plus sign when I depress left mouse button.
Try crtl + S when the menu comes up.
8/13/2009 4:15:08 PM • Dell 2 Button... • Answered on Aug 13, 2009
Left click on mouse pad doesn't work!!!
i think u must have switched the primary and secondary buttons on ur mouse.i assume ur using windows.goto control panel-->mouse-->choose buttons tab-->u'll see a check box which sud read switch primary and secondary buttons.remove the check mark from here.sud solve ur issue...
6/22/2009 4:25:36 AM • Dell 2 Button... • Answered on Jun 22, 2009
Opened dell mouse
I suggest going to a computer repair store and seing if they can fix it - shouldn't be that expensive.
1/7/2009 2:15:23 PM • Dell 2 Button... • Answered on Jan 07, 2009
Switching keyboard and mouse
Mice and keyboard are the two most basic input devices for the modern computer. Not much is needed to change them out.
Turn your computer off. Remove the old keyboard and mouse. Connect the new keyboard and mouse into an available usb port. Restart your computer.
You may have to wait anywhere from 30 seconds to a few minutes, depending on your computer, before the operating system recognizes the new hardware, but once it does, it will start responding.
9/30/2008 1:39:20 AM • Dell 2 Button... • Answered on Sep 30, 2008
Mouse left click problem
it is possible you changed the scheme for your mouse pointers.
you can reset it back to the windows default by going to "control panel", then if you are using the catagory view, you would select "printers and other hardware" Next, select "mouse".
( if using classic view, simpy select "mouse" from the control panel).
Next, while on the "mouse" screen, select the "pointers" tab. At the top, there is a drop down menu for " Scheme". Choose either None, or Windows Default, and then click "apply" and then "ok".
Close out all control panel boxes and test.
Good Luck :)
9/30/2008 1:31:19 AM • Dell 2 Button... • Answered on Sep 30, 2008
Left click not working
This problem of yours has a simple solution:just change the left push to on switch.desolder the original one, get a switch from the local electronic market of the same type(if possible OR another one which will b placed correctly on d pcb and which ensures that d click works)
The problem is that the spring in d switch has lost it's physical properties,which is a aging problem.
Solder the new switch,and there u go,click click click,all working fine.
6/8/2008 10:01:07 PM • Dell 2 Button... • Answered on Jun 08, 2008
Dell mouse: right click shows and scroll curser not spellcheck
Try a different mouse on it to see if it does the same thing. Your mouse might be failing on you. If it does the same thing with a different mouse then it might be the software problem or perhaps drivers. You can also try to uninstall and reinstall the drivers for your mouse. If your running windows 2000 or later version of windows you can uninstall in device manager and restart the computer with the mouse still connected and windows should reinstall drivers for the mouse automatically. Goodluck!
2/2/2008 7:40:26 PM • Dell 2 Button... • Answered on Feb 02, 2008
Button Problems
Sounds like the button on the right might be sticking. I would replace the mouse.
8/17/2007 11:41:34 PM • Dell 2 Button... • Answered on Aug 17, 2007
Dell 2 Button Mouse 6u226 Logo
Popular Tags
26 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
  • Dell Computers & Internet
Most Popular Question
dell 2 button mouse
  • Computers & Internet
