20 Most Recent Konica Minolta Vintage Minolta Sound 6000 Movie 8mm Sound Projector -excellent..- Questions & Answers
Where are the belts located
Model would help
4/28/2019 6:25:14 PM • Konica Minolta... • Answered on Apr 28, 2019
Lamp stopped working. Replaced. Still doesn't work. Why?
check the power supply and or the fuse Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/14/2017 3:52:44 AM • Konica Minolta... • Answered on May 14, 2017
2answers
What is the p5, p9, p16 & L-4 error code mean in konica C754 ?
Replace the Black drum and developer unit (P9) (P16) and clean the IDC forward sensor(P5) (Requires removing the Transfer belt) L4 Black Drum Rotation well passed its life.
4/22/2024 1:19:49 PM • Konica Minolta... • Answered 2 days ago
O que posso fazer para remover o erro de codigo C-D252 na Konica Minolta C364 bizhub
English only on Fixya please. We are a North American website.
Error Code Pls help - Konica Minolta
Copytechnet https://www.copytechnet.com > ... > Konica Minolta Jun 20, 2012 - CD252 (C-D252) code at start up. Solution CAUSE: The Controller 1 setting is enabled in Tech. Rep. Mode without the IC-409 (Fiery® ... fuser error code C252 May 7, 2014 Bizhub C451 bad print quality, no accurate color Jun 4, 2014 Error Code Bizhub 283 with C-D272 Mar 17, 2016 error code C- D251 bizhub C451 May 19, 2009 More results from www.copytechnet.com
Konica-Minolta bizhub C452 - Error Code
Printcopy.info https://printcopy.info > model=bizhub+C452 Code: CD252; Description: No relay circuit boards for IC-412 mounting at IC-412 mount setting; Causes: MFP board (MFPB) Relay circuit boards (VI-505) . ..
3/3/2024 9:54:07 PM • Konica Minolta... • Answered on Mar 03, 2024
2answers
Konica Minolta Bizhub C454. How to download firmware please?
C454 and C454e firmware - Page 2
Copytechnet https://www.copytechnet.com > ... > Konica Minolta May 4, 2019 - Re: C454 and C454e firmware. Hi there, I hava Konica Minolta Bizhub C454 with ROM Version: b-IZHUB-c454 - imgbb.com C454 and C454e firmware May 5, 2019 UPDATE FIRMWARE ON c454 Jun 19, 2015 Bizhub latest firmware? Mar 10, 2022 Firmware question Jun 19, 2019 More results from www.copytechnet.com
Updating the Firmware of This Machine
Konica Minolta Manuals https://manuals.konicaminolta.eu > contents User's Guide. bizhub C554 C454 C364 C284 C224 ... A firmware for this machine can be downloaded from the Internet to update the machine firmware.
Download Center - KONICA MINOLTA
konicaminolta.ge https://www.konicaminolta.ge > download-centre The download center of Konica Minolta! Find everything from driver to manuals of all of our bizhub or accurio products.
2/16/2024 1:29:36 PM • Konica Minolta... • Answered on Feb 16, 2024
Konica Minolta Dialta 2510 Copier. How to solve C0045 error in 2510 dialta all in one printer
Question edited for a lot more clarity and add maker. Question moved to maker category. Cooling Fan failure.
Konica-Minolta Di2510 - Error Code
Printcopy.info https://printcopy.info > model=Di2510 > code=C0045 Code: C0045; Description: Cooling Fan Failure • The Cooling Fan Motor Lock signal remains set to H for a set period of time while the Cooling Fan Motor is ... Missing: dialta ‎' Show results with: dialta
Error Codes > Konica-Minolta > Di2510 > page 1
Printcopy.info https://printcopy.info > model=Di2510 Code: C0045 · Description: Cooling Fan Failure The Cooling Fan Motor Lock signal remains set to H for a set period of time while the Cooling Fan Motor is ...
2/11/2024 5:27:31 AM • Konica Minolta... • Answered on Feb 11, 2024
Konica minolta bizhub c 7000 error code c 2221 how to fix?
Any one of the following might cause that code, AC drive board (ACDB) • Printer control board (PRCB) • 1st transfer pressure release motor (M19) • 1st transfer HP sensor (PS15 Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2/4/2024 10:14:58 PM • Konica Minolta... • Answered on Feb 04, 2024
HOW TO RESOLVE CODE C-2221 KONICA MINOLTA BIZHUB C5500
1.The terminal for the first transfer pressure/release sensor is not connected properly. Reconnect the terminal. 2.Failed PS15 (p/n 08AA 8551 2). Test photosensor, PS15, in the I/O State Confirmation Mode, 48-0HIGH = home position or LOW = Other than home position by activating M19 (p/n 08AA 8003 0) transfer pressure/release motor, 48-0, 48-1, 48-2, or 48-3. Replace thephotosensor or motor as needed. 3. Possiblefailed Transfer/Pressure Release motor (M19). Check the operation of the motor(p/n 08AA 8003 0) in the I/O State confirmation mode for proper operation with code 48-0; this should rotate the motor constantly. Replace motorif needed. Also check for possibleopen ICP fuses, ICP3 (5V DC)and ICP4 (24V DC) on the AC drive board (p/n A03U H520 01). Replace the drive board as necessary. SPECIAL NOTE : Solution contribution by KMBT (Japan) and Freddie Burnham, Production Print/SSD
2/1/2024 10:59:06 PM • Konica Minolta... • Answered on Feb 01, 2024
2answers
I have 3 Konica Minolta Bizhub 287 that are making pale copies, what is happening?
Usually this happens when machine is operated in environment that does not fulfill the recommended environment i.e. temperature and humidity. Similarly, if toner cartridge is refilled with toner that does not match the category which is recommended, lighter print are observed. If toner is about to end, same also happens. See the environment conditions in the manual and replace toner cartridge with genuine cartridge. Operation Precautions; Power Source; Operating Environment; Storage Of Copies - Konica Minolta bizhub 367 Quick Start Manual [Page 28] ' ManualsLib
1/14/2024 1:54:56 AM • Konica Minolta... • Answered on Jan 14, 2024
1. Can Konica Minolta Bizhub 220 scan or print from flash drive? 2. What can I do if printing on black and white is fainting and there is enough toner for my Konica Minolta Bizhub 220. Thank you
All in the link. You can't Scan FROM a USB drive because if it was on the USB Drive it is already in digital format. You can Scan TO a USB Drive. For the faint text, remove the toner cartridge and give it a couple of hard taps on the either end to settle the toner. Then run a Test Page https://www.google.com/search?q=Minolta+Bizhub+220+scan+or+print+from+flash+drive ..
12/29/2023 10:56:13 PM • Konica Minolta... • Answered on Dec 29, 2023
Konica Minolta Bizhub C220. It has error code C2557 constant paper jam and faint black and white printout
What is error code c2557 on Konica c220? Check the toner bottle to ensure that it is feeding toner into the sub hopper unit under the bottle. Sometimes users will insert the bottle incorrectly and not lock it properly in place...the lever on the front of the toner hopper for that bottle is moved down to the left to remove and insert the bottle. Dec 28, 2010
Error code C2557 - Konica Minolta - Copytechnet
12/27/2023 12:27:46 AM • Konica Minolta... • Answered on Dec 27, 2023
2answers
Driver for konica minolta 7216
12/25/2023 1:37:26 PM • Konica Minolta... • Answered on Dec 25, 2023
I HAVE A KONICA MINOLTA 190F COPIER PLS DIRECT ME ON HOW TO COUPLE THE DRUM ITSELF TO THE HOLDER
Please refer to the service manuals and this.
Replacing a Drum Unit
Konica Minolta Manuals https://manuals.konicaminolta.eu > contents After Drum Unit replacement step 1 has been completed, check that the red-circled lock is located at the position indicated by a dashed line, then execute step ...
Konica Minolta REGIUS 190 Service Manual
ManualsLib https://www.manualslib.com > ... > REGIUS 190 View and Download Konica Minolta REGIUS 190 service manual online. REGIUS 190 medical equipment pdf manual download. Also for: Dd-941.
Konica Minolta - Regius 190 Community, Manuals and ...
MedWrench https://www.medwrench.com > equipment > konica-m... Konica Minolta - Regius 190 by Konica Minolta. Konica Minolta - Regius 190. Forums ... Regius 190 Service Manual. SERVICE COMPANIESView All Computed Radiography ...
Konica Minolta Regius 190 (DD 941) Service Manual
Internet Archive https://archive.org > details > manual_Konica_Minolta... May 20, 2020 - KONICA MINOLTA. DIRECT DIGITIZER. REGIUS MODEL 190. (DD-941). SERVICE MANUAL. KONICA MINOLTA MEDICAL & GRAPHIC, INC. ..https://www.youtube.com/watch?v=lqfANSFl6Io
10/6/2023 2:25:30 AM • Konica Minolta... • Answered on Oct 06, 2023
Can you run 9 x 12 envelopes on Konica Minolta Bizhub 880 from LCT tray
You can try it, but the manual says 10 at a time via the Bypass tray. The problem is the fact that normal paper from the trays takes a rather tortuous route through the machine that contains sharp turns. By far the easiest way to print a lot of envelopes is to use Avery 8163 Labels. Use the Avery template and create the pages of addresses and print 50 at a time from the normal paper tray. https://www.google.com/search?q=Konica+Minolta+Bizhub+880+print+9+x+12+envelopes
Template for Avery 8163 Shipping Labels 2" x 4"
Avery https://www.avery.com > templates > 8163 Avery® Erasable Multi-Use Removable Labels, 7/8" x 2-7/8", W... ... Avery® Printable Tags with Sure Feed, 2" x 3-1/2", White, 96... ... Avery® Easy Peel® Address ... ..
10/6/2023 2:06:38 AM • Konica Minolta... • Answered on Oct 06, 2023
Buenos dias. Mi consulta es La impresora Konica minolta bizhub C652 tiene en la pantalla un error que dice C 6301 Como puedo arreglarlo Gracias
  • Code: C6301
  • Description: Optical cooling fan motor's failure to turn • The fan lock signal remains HIGH for a predetermined continuous period of time while the motor remains stationary.
  • Causes: Optical cooling fan motor (M202) Scanner relay board (REYB/SCAN) MFP board (MFPB)
  • Remedy:1 Check the FM201 connector for proper connection and correct as necessary. - - 2 Check the fan for possible overload and correct as necessary. - - 3 M202 operation check REYB/SCAN PJ4-3 (LOCK) P-18 4 Change REYB/SCAN - - 5 Change MFPB
https://www.google.com/search?q=Konica+Minolta+Bizhub+C652+printer+error+C6301 ..
8/10/2023 5:28:48 PM • Konica Minolta... • Answered on Aug 10, 2023
Good morning, my Konica Minolta 190f says:please call service 001,what will I do to resolve this
Error code 001 is a generic service call error, and it could be related to various problems within the printer.To resolve this issue, follow these steps:
  1. Power Cycle: Start by turning off the printer, unplugging it from the power source, and waiting for a few minutes. Then, plug it back in and turn it on again. Sometimes, a simple power cycle can clear temporary glitches.
  2. Check for Obstructions: Ensure that there are no paper jams or any obstructions inside the printer that may be causing the error. Clear any paper jams carefully if you find any.
  3. Reset Printer: Look for a reset button or a specific key combination in the printer's manual or documentation. Try resetting the printer to its default settings to see if the error clears.
8/6/2023 7:13:01 AM • Konica Minolta... • Answered on Aug 06, 2023
Konica Minolta Bizhub C552. How to reset error code c6752 please?
Trouble Code C-6752 Reset on Konica Minolta C220/C280 ...
CORONA TECHNICAL https://www.coronatechnical.com > 2019/07 > trouble-... Jul 12, 2019 - This code means is related to CCD. When starting the scanner, verification of reading and writing the predetermined value for image processing ...
8/5/2023 5:02:38 PM • Konica Minolta... • Answered on Aug 05, 2023
Konica Minolta DiALTA Di 152 Copier. Azzerare manutenzione minolta dialta di152
Question edited to add English make and model. Question moved from Cars and Trucks category. English only on Fixya please. We are a North American website. Reset maintenance minolta dialta di152. Cruet of oil. And this is the problem. Copiers have a 'cruet of oil'? And they do! https://www.google.com/search?q=minolta+dialta+di152+oil+tank ..
8/5/2023 12:39:49 AM • Konica Minolta... • Answered on Aug 05, 2023
Konica Minolta Vintage Minolta Sound 6000 Movie 8mm Sound Projector -excellent..- Logo
4 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
belts located
  • Office Equipment & Supplies
