20 Most Recent
Dell 1700 Laser Printer Questions & Answers
Dell 1700 laser printer wont load from tray only manual
This is a common misconception with this model printer. People say that the roller does not drop down to pick up the paper. With this model printer, the pickup rollers ONLY drop when the paper tray is inserted. If you look on the top left edge of the paper tray towards the front of the printer you will see 1 1/2" to 2" section where the plastic edge is raised about 1/2 an inch. This raised part in the plastic actually serves as the mechanism for dropping the pickup rollers on to the paper.
So... The solution DOES HAPPEN TO BE cleaning or replacing the pickup rolers/tires. Rubber rejuvinator is the best for cleaning the rollers, but buying a whole can that you may only use once or twice may be a bit overkill. You can try cleaning them with soapy water if you do not have any rubber rejuvinator. DO NOT use alcohol, as this will dry out the rollers and shorten their lifespan even more.
USB Port Dell 1700 Printer
On the back side of the printer (left side) below the parallel port and below the LAN (ethernet) port is the USB port. It looks like a barn door. The cable you would need to use is an A/B USB cable. it has the standard rectangular usb port on one end and the funny barn door that is used by printers and scanners on the other end. I hope this helps. I’m happy to help further over the phone at
https://www.6ya.com/expert/anthony_db0df2be5e6f8c0c
I have a Dell 1700
After you replace the imaging drum, you should reset the imaging drum's counter. To
reset the counter, press and hold the Cancel button until all lights flash in sequence.
We have a worksheet in Quattro Pro. We get the
Hi milt_sheila,
This type of error message is often caused by either something has been changed in the program or your operating system. The easiest way to correct this is to uninstall and reinstall the program (Quattro Pro). Reinstalling the program will reset everything back to the state where it is working properly.
Hope it helps.
Thank you for using FixYa.
I cannot cancel a job
Hi, if showing, right click printer icon on bottom of screen. Menu if showing, click jobs waiting.
Right click on the work you wish to cancel, menu click delete, that should clear the box of the print job.
Alternative. Click Start/Printers & Devices/Right Click Default Printer/Click Properties/Click See Whats printing/Right click print job menu/Click dropdown Delete.
What makes a printer print
I have the exact same problem. Print is great on the left side of the page, but too light to read on the right side. Have already replaced both drum and toner cartridge - still same problem.
Dell says I low toner, replaced cartridge, same
Unless your 'new' cartridge has a used chip, it's likely that the pagecount for the Photoconductor/Drum Unit is at the replace stage.
The Drum unit has a small waste toner collection container, is this becomes over-full, waste toner 'spews' into the printer with dire effects. This is ONE of the reasons that drum units have a rated pagecount.
You can reset the drum counter without actually replacing the drum, but this should be used as a short term measure ONLY, AND AT YOUR OWN RISK.
The Photconductor reset procedure is as follows.
Dell 1700
RESETTING DRUM PAGE COUNTER
1) Leave the power on, insert toner cartridge, and leave door open
2) Press the cancel button and hold till the leds flash
3) Release cancel button and close toner cartridge door
All the lights ar fleshing and the printer dident
1. Turn off your printer on its back
2. Open the front cover
3. Push and hold continue and cancel buttons while turning the printer on again.
4. release when only the error led is lit
5. Close the front cover
I have no printer driver
go to dell.com and there are going to find the driver you are looking for
may find the program you need
