20 Most Recent Dell OptiPlex SX270 PC Desktop Questions & Answers
Error Code 0F00:1344 - Msg: Block 2242 uncorrectable data error or media is write protected
Sounds like your hard disk drive is about to fail.
3/23/2014 10:51:27 PM • Dell OptiPlex... • Answered on Mar 23, 2014
0answers
0answers
Why there is no audio?
Product Selection ' Dell US I sure hope this helps you :)
12/12/2013 9:56:15 PM • Dell OptiPlex... • Answered on Dec 12, 2013
3answers
Sx270 built in video driver won't work with my
Please click here download the driver, and read the instruction to install the video driver.
CompQ
12/11/2013 9:44:01 AM • Dell OptiPlex... • Answered on Dec 11, 2013
0answers
Capacitor c270
Be the first to answer 11/18/2013 11:58:46 PM • Dell OptiPlex... • Posted on Nov 18, 2013Be the first to answer
Keyboard failure
if its usb move to different slot and try it. that did not work try a different keyboard
11/12/2013 6:55:22 AM • Dell OptiPlex... • Answered on Nov 12, 2013
Why is there no sound?
FIrst thing you have to do is find out wther you computer install with proper sound driver. to do that you have to right click your my computer icon then click properties, then Hardware, then Device Manager . now you'll see a small window will apear , there locate 'sound,video and game controller', if this option is highlghted with yellow question mark then there is no proper driver install in your computer so you need to find out which mother board you are using and you should have driver CD of that marticular mother board.
7/13/2012 12:48:43 PM • Dell OptiPlex... • Answered on Jul 13, 2012
Fitted new battery still says voltage is low
If its still showing low battery,then recheck that you inserted proper new battery.If you have any more spare battery try that too.But if its still showing same battery low message,then click the link below :----http://technoanswers.blogspot.com/2012/01/low-batery-message-on-dell-optiplex.html -------This will help.Thanks.
1/27/2012 7:20:57 PM • Dell OptiPlex... • Answered on Jan 27, 2012
2answers
What is low battery warning on dell sx270...
CMOS battery, also known as a coin cell battery. Here is a link to the manual at the Dell support site that explains about the battery.
http://support.dell.com/support/edocs/systems/opsx270/en/ug/battery.htm#1095363
1/27/2012 6:31:13 PM • Dell OptiPlex... • Answered on Jan 27, 2012
I cant hear or talk
Hi mano try going on the dell site upload new drivers for sound card regards clive
1/27/2012 3:48:28 PM • Dell OptiPlex... • Answered on Jan 27, 2012
Has clicking sounds and
Hi john sounds like the dvd rom is up the spout regards clive
1/27/2012 3:46:31 PM • Dell OptiPlex... • Answered on Jan 27, 2012
How to off cover to
Hi jeff you will need to take cover off heatsink to take battery out got 6 dell sx270 ,if you need part i got loads regards clive ,regards [email protected]
1/27/2012 3:41:57 PM • Dell OptiPlex... • Answered on Jan 27, 2012
Dell optiplex not booting from xp cd
If your laptop screen is not working and is blank, you are out of luck as far as working on your computer. However, while there may be a major problem you need to troubleshoot, there are some easy solutions to keep in mind as well, such as brightness settings and your power source.
1. Check the power source. While you have presumably already attempted to turn your laptop on and off, the problem may lie with your AC power adapter. Is the power-indicator light on the adapter on? If not, your problem may lie here. However, whether or not you have a power indicator light on your adapter, consider unplugging it and plugging it into another outlet. This may turn on your laptop and take care of your blank-screen problem.
2. Check your brightness settings. While it seems like a simple oversight, the brightness on your laptop may sometimes be turned all the way down. Thus, the screen appears to be black, off or defective, when the problem is simply that the brightness is on its lowest setting. To fix the brightness, check your laptop keyboard. Most laptops have the brightness settings mapped to two keys at the top left of the keyboard, accompanied by a symbol (often a sun). Use these keys to fix your brightness, but keep in mind that some laptops require that you press the Function key at the same time as the Brightness key.
3. Check the status of your laptop battery itself. There should be a battery indicator on the laptop that is connected to the battery. This indicator is either on the bottom of the laptop or (likely) on the side. If there is no indicator, your battery itself may be the problem, and may require replacing. Keep in mind that older batteries of the nickel-cadmium variety are more likely to decharge over time and forget their initial maximum charge level; this may be a particular issue to users of older laptops.
4. Find a VGA connector and hook up your laptop to an external monitor if the above steps have not alleviated the blank-screen problem. Turn on the computer and the external monitor. Does the external monitor light up? If so, the blank screen is likely due to a video subset problem/LCD problem in your laptop.
5. Consider that a deeper problem may exist if the external monitor did not light up This problem may lie in the motherboard. In this case, taking the laptop to a professional repairman or sending it off to the manufacturer is recommended.
I hope you find it very helpful. Best regards from fixya
8/15/2011 4:54:43 PM • Dell OptiPlex... • Answered on Aug 15, 2011
2 short beeps with error
Check your memory, remove then plug it again. To make sure this is your memory problem or not, you can use different memory.
8/6/2011 10:36:58 PM • Dell OptiPlex... • Answered on Aug 06, 2011
Dell OptiPlex SX270 PC Desktop Logo
97 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
OptiPlex Dell
  • OptiPlex Dell
Most Popular Question
sx270 built in video driver work
  • Computers & Internet
