20 Most Recent Dell Dimension 2300 PC Desktop Questions & Answers
DETAILS,DETAILS,DON'T FORGETT THE DETAILS.
Dell Dimension... | Answered on Oct 12, 2014
It Sounds Like Your PC Is Defective Because First Of All There Shuld Not Be A Power Button Connector To
Remove In The First Place And Second The Power Button is What You Turn On The PC With So It Is
Best To Replace The PC With One That Uses An Intel Pentium 4 Prosser!
Dell Dimension... | Answered on Oct 11, 2014
Sounds like your video patch cable is bad most likely one or more bent pins.
Dell Dimension... | Answered on Aug 17, 2014
You should start it with the DVD that came with it, containing the clean installation of operating system. Or, if there is recovery partition created, you can install it from there by pressin ctrl + F11 simultaniously when starting the computer.
Dell Dimension... | Answered on Jun 04, 2014
try to install from recovery disk. if not available try to get it from local service center.
Dell Dimension... | Answered on Nov 21, 2013
Do you want to replace it or add it as a slave drive....is your hard drive bad or just limited use...there are different jumpers that need to me set for different way of installation....do you have a new license for installing an operating system....several questions come to mind...I've replaced several and added slave units but it differs.....Can you give me more details and I may be able to assist you with your endeavor....Do you have an alternative method for accessing the internet or better yet, fixya website?
Dell Dimension... | Answered on Oct 18, 2013
Ok, what I am going to do is show you how to bypass or (hack) a password protected windows xp computer. first, restart your computer>press F8 before it boots up, a menu will come up>select safe mode>restart in safe mode>the admin account comes up> click on it and click yes when the small menu comes up> the computer should boot to the desktop now>select start>control panel>select user accounts>select change account and follow the prompts to creating a new account (make sure that the administrator radio button is selected) put in your new password, etc> restart your computer. You should now have administrator privileges on that system. Let me know if you have any further problems. :-)
Dell Dimension... | Answered on Oct 25, 2012
you can technically "rename" any partition but you cannot change drive letters on the boot partition c:. I would uninstall some programs from the c: and reinstall them on the f:. There are 3rd party products like partition magic that let you re-size partitions but the good ones are not free.
Dell Dimension... | Answered on Apr 06, 2012
This may be because of the following reasons.
1: Your SMPS may be faulty
>In this case you can replace it easily.
2. Your Motherboard can be faulty.
>In this case, you may need assistance of a trained service technician to check the whole circuit of motherboard.
3. May be the power cable to your CPU may be faulty
>Replace it with a new one.
Dell Dimension... | Answered on Dec 31, 2011
This may be due to several factors:
1: You may have installed an "always active" programs(like some anti virus or spyware) which may be eating your RAM space... Remove those and always remember that only install software which your system can stand up to.
2: Try to clear temp files by doing Start>Run> Type "%temp%">Delete all files in that..
Note: Some files may be active and you may not be able to delete those...
3:May be you are having a possible virus attack. Try to remove it by using a good antivirus(which also suites your system)
4: Now If problem persists then try to format your system and make a fresh install of your OS.
For a Dell Dimension 2300 PC Desktop, you can download updates from http://www.driversbay.com/drivers/desktop-pc/dell/
Compare the drivers of your PC with that listed there, download the newer version of drivers and install it...
YOu can refer to this site..they are all the same procedure in adding hard drive in a computer.
http://www.infohq.com/Computer/adding-second-hard-drive-review.htm
melnavz
Dell Dimension... | Answered on Dec 09, 2011
Check the floppy drive to see if there is a disk in it....if so, remove it and try booting up the computer again.
Dell Dimension... | Answered on Nov 20, 2011
Simply open the page" www.google.com" and type in "sound drivers" press enter. The drivers would be available for download.
Dell Dimension... | Answered on Sep 14, 2011
Check if your modem/router is functioning first by using maybe a different computer
Dell Dimension... | Answered on Jun 28, 2011
If your files are in "My Music" and the "My Documents" is not shared, then nobody can view them from another PC. Try copying the files to your shared files directory and see if you can access them then.
Dell Dimension... | Answered on Jun 21, 2011
Generally, yes, if it's the same version, (e.g., "Home Edition, or "Professional", etc.Then the Operating System disk should get you going well enough to start all the necessary updates You may need to go to Dell and download the model specific driver files, updates, etc. to get everything !00%
Make sure you have the right Microsoft Product key for the installation.
Best thing you can do is back up your system and keep it somewhere separate, with all this info. There are many good free utilities for system specs., such as Belarc Advisor. It's easier to fix a broken system when you can automatically put everything right from backups, where ever possible.You are thinking ahead, instead of after a disaster!
Good luck.!
Dell Dimension... | Answered on Jun 03, 2011
Dell Dimension 2300 PC Desktop Logo
115 questions posted
Ekse
Thomas F. Schneider
Shawn DuRee
View Most Popular
Dimension Dell
  • Dimension Dell
Most Popular Question
get free pc drivers updates
  • Computers & Internet
