20 Most Recent Belling XOU270 / XOU271 Electric Single Oven Questions & Answers
2answers
Belling Synergie
NEED NEW FAN OVEN ELEMENT THAT CAN BE FOUND HERE You need Element code AB20 on link belowhttp://cookerandovenelement.co.uk/bellingfanovenelement.htmlelement is located on back wall of oven you need to pull oven oven to remove the element element is held by two nuts from back and i screw from front
12/24/2012 7:11:21 PM • Belling XOU270 /... • Answered on Dec 24, 2012
I turned on the oven last night & it tripped
you need to upgrade your beaker
8/13/2011 7:10:28 AM • Belling XOU270 /... • Answered on Aug 13, 2011
No heat from oven although fan and light are both
hello gavin..... Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
This is an inexpensive part and relatively easy to replace. Call your local appliance store to obtain the part and the instructions on how to install it. Joe
Thanks for choosing Fixya!
1/5/2011 8:19:13 AM • Belling XOU270 /... • Answered on Jan 05, 2011
The oven stopped working but
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
12/25/2010 1:10:36 PM • Belling XOU270 /... • Answered on Dec 25, 2010
Just had heater element tested and its ok,oven
Yes the thermostat is the most likely problem, you can easily replace it.
12/11/2010 1:13:48 PM • Belling XOU270 /... • Answered on Dec 11, 2010
The oven stopped working so I replaced the oven
Re:The oven stopped working so I replaced the oven element (ES101150) successfully. Now a year later the grill has stopped working so I replaced the grill element (ES548158).
The first success had been a lucky dip. before replacing an element you have to read Ohms at element, if reads infinity (open) replace it, if not, read volts coming from timer board.
Re:Now the fan, the oven, the light and the grill all don\'t work but the timer still works. Is there an internal fuse somewhere ?
There is no fuse. Depending on the country of use, the power cord may be fused, but if the timer is working, that is not the problem.
The grill element should be a double element in this model. Grab the old grill element and read Ohms, to find out if the old one was open. If one of the elements was open, then the element was bad. If it was not , then there was a different problem causing no heat. The circuit comes from timer board, passes through temperature sensor and powers fan and element. The job is done reading Ohms to find out if there is an open in wiring to grill, and if there is none, reading Volts at OEC (oven timer) contacts to find out if timer is working (timer is expensive).
Parts for this oven are scarcely available from third party, better ordering from manufacturer through the number listed on the owners manual.
8/29/2010 9:51:20 AM • Belling XOU270 /... • Answered on Aug 29, 2010
tip
How to diagnose, fit and change a Belling fan oven element.
If your fan oven is not heating up properly the Fan Oven Element for your Cooker is usual culprit. Fitting an oven element is generally very easy, as demonstrated by The Apart4u video on How to change repair and replace your fan oven element:this fan oven element can usually be changed without taking the appliance out of situ.
WHY CANT I TAKE ELEMENT OUT
If you cannot remove screws from inside oven compartment, then, yes, it will be neccescery for you to remove the oven from it's housing to gain access to the screws from the rear.
5/4/2010 9:24:07 PM • Belling XOU270 /... • Answered on May 04, 2010
Cannon 10287G gas - lower oven flame no longer
Nope- It's most likely the ignitor. Resistance should be above 4ohms. Accessible below drip pan. 40-75$ local app. parts store. Hope this helps- ED
3/15/2010 7:31:50 AM • Belling XOU270 /... • Answered on Mar 15, 2010
My hob is working but there was a bang in the oven
If it is a fan assisted oven, and the fan is working o/k, then I would suggest that you fit a new oven element, if the fan is not working, then you are going to have to investigate further.
Please rate my solution.
Thanks.
11/8/2009 10:48:03 PM • Belling XOU270 /... • Answered on Nov 08, 2009
The fan assisted oven has stopped heating up how
If the fan is working o/k, then you needs to replace the oven element located at rear of oven compartment.
Thanks.
10/29/2009 8:23:57 PM • Belling XOU270 /... • Answered on Oct 29, 2009
Oven will not heat past 100 degrees
More of a clarification request:
Is the oven remaining on all the time(oven light stays on)and the temp not going above 100 ,or is it going to 100 then switching off?
8/10/2009 10:56:01 AM • Belling XOU270 /... • Answered on Aug 10, 2009
Replace Bottom Element in Belling XOU270
If this is a fan assisted oven, then there is no bottom element, only the fan element..
Remove the panel at the rear of the oven, there you will see the element, remove any screws that you can see and pull element towards you, disconnect the leads, don't loose them, and replace element.
If no screwws are visible then you will have to remove the oven from housing and do it all from the rear of the oven. Make sure power is off before you do anything.
Good luck.
Plz rate my solution.
Thanks.
12/16/2008 4:18:23 PM • Belling XOU270 /... • Answered on Dec 16, 2008
Cooker is a Belling XOU270 / XOU271
You need to replace the fan oven element.
12/16/2008 3:03:24 PM • Belling XOU270 /... • Answered on Dec 16, 2008
Just got a new Belling Sandringham Farmhouse range cooker [DF 100-cm]
turn power off to unit look at point were hard cable joins cooker uncover and check the bridges in the junction box are correct
12/9/2022 1:21:33 PM • Belling Ovens • Answered on Dec 09, 2022
How do I remove front control panel on electric Belling induction oven
Hey Kevin, thank you for the question. Can you please provide us with your model number, we will assist you better.
9/24/2022 6:24:01 AM • Belling Ovens • Answered on Sep 24, 2022
Belling XOU270 / XOU271 Electric Single Oven Logo
27 questions posted
Top Belling Ovens Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
David Spradling
David Spradling
Are you a Belling Oven Expert? Answer questions, earn points and help others
View Most Popular
Belling Ovens
  • Belling Ovens
Most Popular Question
belling synergie
  • Ovens
