20 Most Recent
Dell (1G055) CD-RW/DVD-ROM (Combo) Burner Questions & Answers
Dell Cd/Dvd burner not working properly
I have a Dell XPS 400 that's about 3 years old. I have a DVD reader and a DVD-RW device. The former works - the latter takes forever to read discs (particularly DVD data discs.)
I'm starting to think some of the generic DVD-RW devices Dell uses in its computers are prone to early failure. The DVD-RW in my XPS-400 was called "HL-DT-ST DVD+-RW GSA-H21N".
I'm going to try cleaning it, and then just swap it out for a better device.
Dvd doesnt read a lot
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. oryou might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
I was burning copies of
There should be a small pin-hole on the laptop's DVD drive. Find a needle or a paper clip and push it into the pin hole. This should either manually eject the disc or pop open.
If you do not have a pinhole on your DVD drive, go to My Computer > DVD Rom Drive
Right click on your DVD Rom Drive, and click "Eject".
This should remove the disc.
Hope this helped!
My cd burner doesn't read
you might have to physically unplug the leads for this cd rom then plug them back in this should activate the found new hardware wizard
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
if your computer came with a motherboard disc the sound drivers could be on it
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete After deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.hope this helps
My pc asking to connect to a burner
the stock drive on that unit is a cd reader only. it will not burn discs. you need to attach a usb cdburner or purchase a new internal drive that has cd burning abilities.
Hello. DVD drive for
I had the same issue with my laptop from Dell. I purchased it in 2005, and by 2009 I had the burner unit replaced 7 times. They would work for a short time, and then stop burning. After awhile they wouldn't even play disks, never mind burning them. I never received a satisfactory answer from Dell as far as why I had to keep replacing the unit. They just kept sending me replacements for as long as my warranty was good. I had purchased and extra 4 years of warranty thankfully enough. I have over 30 years of experience with computers, and have never seen so many of the same hardware item replaced in such a short time. I think the reality of the situation is that Dell buys the cheapest units they can get their hands on. They are not to worried about warranty replacements as they send them back to the manufacturer. Once you are out of warranty, as I was after the last time the unit quit on me, their telephone people then tell you to replace your computer with a newer one as yours is just so old now.
You can try and reload the driver from the Dell site for your laptop. If you go to their supports site and enter your Service Tag number you will get a list of all of the drivers that are specific to your machine. Download the drive for your burner, and then double click it to install the driver. Most units have more than one type of burner listed so be careful to make sure you download the correct file. Hopefully that will take care of the issue. If not, and you still have a warranty, contact their support line and have them send you a new unit.
Thank you for the opportunity to assist you in resolving your issue.
Should you need further information or assistance please do not hesitate
to let us know.
MY CDRW DELL DIMENSION 5150
im not sure what cdrw isnt doing so i will have to guess
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rw/dvd rom burner then plug them back in this should activate the found new hardware wizard or
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Can i take abunner from one dell computer out and
there is no problem on switching similar burners if the destination computer has a free interface connector for the type of connector of the replacement burner since they are plug and play. The form factor is the only thing that could cause problems after that.
Whenever i try to burn
Hi
First of all check you don’t have a trial version of the software while burning cd.
Check your computer to make sure it has a CD burner. Find out if it also has CD writing software. Realize that most computers now do come with a CD burner-you can get one installed, for instance, at a computer repair shop. Download or purchase CD writing software (online or from an electronics store) if you lack the software needed. Buy software, such as "Nero Burning ROM," which also comes with a CD label maker.
Buy recordable CDs. Know that you can record on both CD-R as well as CD-RW, but CD-R is best for recording both music and data, whereas CD-RW is best for data as some audio equipment won't play music recorded on a CD-RW. However, CD-RW is rewritable and is great for saving files and data and then altering what's on it.Insert your blank CD-R or CD-RW. Look for your CD writing software-click the "Start" menu; then click "Programs." Open the software and choose "Wizard" over the "Manual" option if available, especially if you've not used the software before or if it's been a while since you've used it.
Select the option for either data or audio. Remember if you want to backup or save data files from your computer, select "data," but if you want to make a copy of one of your listening CDs, choose "audio" or "music."Open the files or music to be copied from within your CD writing software. Find data or audio easily with the software wizard, or see an option for opening files in the software menu or on the screen (it should be fairly obvious).
A lot of CD writing software has a "drag and drop" option similar to a Windows Explorer type of look and function. Use this feature or copy and paste data or audio you want to put on your blank CD.
Wait for the CD writing software to copy the data or music. Pick "Burn" once the files or audio have been copied-this might take a little time. Avoid messing with your computer while the software is copying or burning because you might end up with an incomplete burning session or a damaged CD.
Check your new CD once the burning session is complete. Open it from "My Computer" or a program on your machine. Look to see if all the data or audio files you wanted copied are there. Listen to your audio CD to check it too if you want.
However check this link bellow if it helps…
http://www.filesforfree.com/acoustica_mp3_cd_burner.htm
http://www.bestshareware.net/acoustica-mp3-cd-burner.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
I have a D620 laptop with a tsstcorp ts-l632d
All burners use 2 lasers - one for the cd and the other for the dvd. In your case the laser for the cd has died and cannot be fixed. You must replace the burner . This one will do the job
http://www.impactcomputers.com/dvr-k16tbc.html
My dell /with a roxio easy cd and dvd program does not recognize
You might have a corrupted registry but it's easy to fix though just click on start - run - type regedit then In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane, click UpperFilters and or LowerFilters then delete both of them (sometimes only one of either of this shows up, but that's ok)
After deleting filters restart the computer and that should fix the problem.
Should you have any other questions just kinldy leave a comment.
Cheers~
Trying to burn a playlist from my itunes account
The ITunes error 4261 appears when attempting to burn CD's. The error code can appear for several reasons, including a faulty CD-RW, used CD's or a slow speed burner.
The error may also occur when you are trying to burn a file that has Dynamic Random Memory from ITunes & you have exceeded your permitted attempts.
The error can also happen if you are accessing the files from a different PC than where it was registered.
Try slowing your burn speed to 16x or even 12x or use Nero Express or Windows Media Player to burn your MP3 files. Other techniques for resolving this error include using new CD's & activating DLA in the Drive Properties.
I truly hope that one of these solutions clearly resolves your problem. Good luck.
Kindest regards,
Ste
CD Rom will Burn CDs But not DVD's. Tried 3 burn
Change your DVD recorder. The DVD's have 2 lassers, one red for CD & 1 Lila for DVD, both are sinchronized on the same lens but is diferent lasser. DVD lasser is wrong, dead, do you need other DVD unit.
I burn the songs to the cd and when i put it in a
Possible that the cd player is not compatible with this type of disc?
Are you burning using "multisession" turned on? If so, try turning this off in your burning software. Some cd players don't like it when you use this option.
Hope this helps.
