20 Most Recent Dell (7W036) DVD+RW Burner Questions & Answers
HI! Need drivers for dvd rw
Check your BIOS settings first.
1/22/2018 7:13:55 PM • Dell (7W036)... • Answered on Jan 22, 2018
No sound from my DVD ,DEll computer ,Windows Vista
Roll back device drivers to an earlier one. SOmetimes newer drivers can cause issues and uninstalling the new and replacing it with an older driver will solve the issue
11/4/2017 1:12:34 AM • Dell (7W036)... • Answered on Nov 04, 2017
Dvd burner for windows has
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps
5/29/2011 10:53:26 PM • Dell (7W036)... • Answered on May 29, 2011
Dvd rw is not working.
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area If this does not fix the problem you might try your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or if this does not fix the problem it might be a registry problem Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.or if these fail to resolve the problem
It could be a problem with the lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
2/5/2011 9:26:45 PM • Dell (7W036)... • Answered on Feb 05, 2011
Windows cannot start this hardware device because
hi there
Remove the dvd writer get new ide or sata cables, and put it in again, but on a diffren ide port, or sata port,
if that doesnt wok get a registry scanner to repair you registry, if that doesnt work resintall windws
try tune up utilities 2010, it shold solve the problem
thanx
11/12/2009 9:37:30 PM • Dell (7W036)... • Answered on Nov 12, 2009
Cannot find drive for 7w036-a01
Hello there:
if you are unable to get it from the manufacture of the device please go to www.radarsync.com and download this 100%freee driver utility, it will update and install any of your drivers and help install drivers for things that you cant get drivers for I.E printers
scanners/ mice/ speakers ect.ect and it is totally free ok?
best regards mike
8/17/2009 12:45:49 AM • Dell (7W036)... • Answered on Aug 17, 2009
2answers
Windows XP wont read DVDS and resolution sucks.
You will need to restore the original software installation. If your warranty is still in effect you will want to contact Dell for service, this is the best possible opportunity for a complete recovery and a happier outlook
7/26/2009 11:48:48 PM • Dell (7W036)... • Answered on Jul 26, 2009
Trying to burn photos from dell laptop to DVD-RW
Try another disc first ,if no luck than try another disc manufacturer. If it does not help check if you can play anything from this drive if no, check drive connection in your laptop you can also can check BIOS settings for this DVDRW drive and settings for IDE or Sata data transfer mode make shure it works in Ultra DMA not PIO mode. Be carefull with BIOS Setup!!! If nothing helps replace drive. Good Luck!
6/24/2009 9:26:49 PM • Dell (7W036)... • Answered on Jun 24, 2009
3answers
Wont burn data dvd
dear
i have this kind of drive ( 7W036-A01) , IT READ AND WRITE CD BUT IT COULDNT WRITE DVD ( EVEN IT READ DVD IN GOOD WAY )
PLEASE CAN ANY ONE HELP ?????
6/12/2009 5:46:31 PM • Dell (7W036)... • Answered on Jun 12, 2009
MY CD DRIVE DOES NOT EVEN REGISTER WHEN I PUT A
Hello Suave8815,
This was a known issue with the Microsoft.. Now fortunately Microsoft has come up with a fix available at:
http://support.microsoft.com/kb/314060
Just download "Fixit" and follow the wizard .. that should help you.
If this solution helps you then please do rate the solution.
Regards,
Srinivas
6/11/2009 5:54:52 AM • Dell (7W036)... • Answered on Jun 11, 2009
Trying to burn photos from dell laptop to DVD-RW blank disc
need to download burning dvd decoder www.slysoft.com or www.filehippo.com
2/27/2009 10:30:56 PM • Dell (7W036)... • Answered on Feb 27, 2009
New dvd burner does not work.
No reply
Can't help without details, sorry
2/9/2009 4:43:19 PM • Dell (7W036)... • Answered on Feb 09, 2009
CD drive is not accessible
reinstall the drivers for the cd drive, in the start menue click on computer when it opens up right click on the cd drive and click on properties click on up date driver
12/1/2008 8:08:45 PM • Dell (7W036)... • Answered on Dec 01, 2008
tip
You Cannot Put 700MB of Data on a 700MB RW Disc: Why?
(This also pertains to DVDs and Solid State Flash Media)
[The point of this Tip is to help you understand in the broadest of terms why you cannot use up all the space on your CD or DVD RW media and your CD-Rs and DVD-Rs as well as Flash Media.]
Lets start with RW media where this causes the most confusion:
You will never be able to format the entire 700MB of any RW media. The same is true for DVD RW media. This is because the formatting requires a file allocation table (FAT) be created, the formatted disc will be segmented into cylinders (circular sections of the disc) referred to as tracks and that is further divided into Sectors. The FAT contains columns and rows that containing information on exactly where data is stored by referencing track and sector within the FAT. The file may span many sectors and be across several tracks. The data and the table takes up a lot of room. A good and easy example of this is a floppy disk. If you have a floppy disk you will notice on the diskette drawer slide it states it is a 2MB diskette, however, when formatted you only have roughly 1.44MB of usable addressable space. The same is true for any formatted RW CD or DVD.
Can this be Different between Media Maker Companies?
Simply stated: No.
Just how much space is available after formatting a RW disc on your system sometimes depends in part on the software used to format the disc. But this will never be different enough between media makers to amount to much. The exception is preformatted discs you may purchase off the shelf. Those preformatted disc may vary from maker to maker.
How about Software driven Burner Programs?
In CD RWs, for example only, the common assumption is that 545MB will be available for data storage. Every software program may be slightly different; each software burner producer reserves the same, more or less space than another. This difference will be slight, if noticeable at all.
How about CD/DVD-Rs then?
Additionally, but aside from RW media. You cannot place 700MB of data on a 700MB CD-R. Room is included on the media for file sector information and label data for Start of File and End of File markers. Each piece of data that comprises a file on the disc, RW or R, has information that is part of a label such as (although greatly simplified) part 2 of 200. I'm not overly simplifying this by example but it is close enough for an average layman to get a grasp of how this works. Each part of a file broken down by sector size (more on this in the next paragraph) on your disc has a marker to indicate which part of the whole it comprises. Your computer uses this data to reconstruct the file when you open it or copy and paste the file. When moving or sending files these parts of a file are referred to as packets.
Space Loss From Sector Size
Another reason for 'space lossage' on RW media is that when formatted, each sector may be 8K, 16K or 32K in size. However, the last sector in a string of sectors for a file rarely fills in the full 8 / 16K or 32K of space. Lets say, for example, that the last sector only has 4K of data and this is an actual average for your RW disc. You end up loosing 4,12 or 28K of space for each and every file on the disc. So in reality you have the 545MB of available space plus the loss of data in the last sector of a series of file segments. When there are a lot of file written to a RW disc, the lossage adds up real fast. Does this also apply to CD-R media? Yes, and can have a dramatic affect. On a 700MB CD-R you will never be able to put 700MB of data on the disc for this reason.
The Same is Also True for Hard Drives on your System
Another good example of this loss of storage size as advertised is with a Computer Hard Drive. A 500GB Hard Drive will not even come anywhere close to the advertised usable space once it is formatted, but when you see your drive in the System, it will be labeled and described as a 500GB drive.
How about Music CD and DVD MP3s?
Music CDs are quite a bit different but and not the same for DVD MP3 discs which are data discs.
When you purchase a CD Disc labeled as a Music CD, it is preformatted for music only. And I'll describe this method shortly. And as a result will not store data.
Music tracks on a Music CD are laid down much like a vinyl album, in one continuous groove that swirls across the entire disc media. At the beginning and end of each track on a Music CD is data, called Meta Data that contains information about the track title and artist/album. As just described for each track holding data pertaining to track title and artist/album, you cannot fit exactly 700MB of music you listen to later. Additionally, the industry standard is to included two seconds of silence between tracks titles, but still on the same continuous groove that comprises the entire Music CD.
Is this True for Solid State Removable Disks like Compact Flash?
Yes, and for the same reason already stated above pertaining to CD/DVD-RWs. When the Flash Media is formatted it also contains a FAT and the media is formatted with Tracks and Sectors. Files written have to have package labels and are formatted into there sectors and where the last sector is occupied with data that is usually less than the sector size and thus it will never be filled up to its maximum capacity.
[As stated earlier, the point of this Tip is to help you understand in the broadest of terms why you cannot use up all the space on your CD or DVD RW media and your CD-Rs and DVD-Rs as well as Flash Media.]
Authors note: As needed, for corrections or additions to this topic I will add notes to this Tip below as comments.
If you need or wish to contact me you can reach me from the Ask button found here or at http://www.fixya.com/users/worldvet/
2answers
Won't burn audio cd
Witch program do you use to burn???
Try NERO and i think it will help you
3/1/2008 12:24:15 PM • Dell (7W036)... • Answered on Mar 01, 2008
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
1/29/2024 9:26:36 PM • Dell Computers &... • Answered on Jan 29, 2024
2answers
Dell Latitude won't connect to internet. Windows XP.
It is too old, plus XP is a virus magnet and has been unsupported by Microsoft for nearly 15 years. Mainstream support for Windows XP ended on April 14, 2009. Windows 7 and 8 have passed you by, Windows 10 is current and Windows 11 awaits. https://www.google.com/search?q=Dell+Latitude+won%27t+connect+to+internet.+Windows+XP ..
1/16/2024 8:34:33 PM • Dell Computers &... • Answered on Jan 16, 2024
Where can I get a replacement adapter cord for my Dell 3052 - 20" all in one model reg model W158?
Amazon, or if you only want the main lead, Walmart.
AC/DC Adapter For Dell Inspiron 20 Model 3052 20- ...
Amazon.ca https://www.amazon.ca > Adapter-Inspiron-20-3052-... AC/DC Adapter For Dell Inspiron 20 Model 3052 20-3052 W15B W15B002 All-in-One Desktop PC Power Supply Cord Cable PS Battery Charger Mains PSU : Amazon.ca: ... $26.27 · ‎ In stock ..
1/11/2024 6:55:07 AM • Dell Computers &... • Answered on Jan 11, 2024
Dell (7W036) DVD+RW Burner Logo
20 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
  • Dell Computers & Internet
Most Popular Question
cd drive not even register when put
  • Computers & Internet
