20 Most Recent
Konica Minolta Bizhub C253 Copier Questions & Answers
Bizhub C253 doesn't work for scan to email
Yes you need to go to the copier's web page and update the the password for the scan to email you do that bye placing the IP address of the copier in the URL box of google. Check out 100's of you tube videos . Just ask how to scan to email using my bizhub c360
How can i re-set a fuser unit on c253
1.Shutdown your machine.
2. Open up the front cover were the iu and toner cartrige are located.
3. Remove the cover.
4.Cut the wires 2 and 3 as long as you can. And connect them with the fuse.
5. Insulate connections and close all doors.
6. Start the machine, wait to warm up, check if the fusing unit is reset and if everything is done, shutdown again, remove the fuse.
How do i re-set fuser unit replacement message on bizhub c253
SIR/MAM
TROUBLE RESET
FIRST, If this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
How do i reset fuser unit error message on bizhub c253
TROUBLE RESET
