20 Most Recent
EPoX (EP-4SGM8I) Motherboard Questions & Answers
Pc goes into power save mode
Motherboard specs show it has integrated audio. Try removing the audio card and connecting sound to the MB audio.
Powersave is OS related not hardware. Look at user settings.
I need manuel
Hello hot_139.
Here's your GEEK-steer ...
You'll find what you're looking for (and more)
here.
Good luck, and thanks in advance for posting back ...
- to let me (and others) know how things worked out.
- if you have any further questions.
- to provide clarification or feedback.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-
Dios and Godspeed -- Craig
Windows not booting
The problem is that your trying to use a hard drive with an operating system that was installed on a different computer, there will be all kinds of problems with that. Format the drive and do a clean install of windows and that should fix your problem. Hope this helps
Getting in to the bios
Try pressing the delete key every two seconds at boot up to get into the bios. F keys are used for pre-assembled systems. They often use F2, F10, & F12 to enter the bios.
Usb 2.0
i think oyur drive had problem change your drive and try it.
EPoX EP-8K7A+ motherboard - memory problems
The first thing i would suggest it so make sure you have the latest Flash Bios installed on your motherboard.
Just for giggles you could try to reverse the dimms just to make sure one of them isnt bad.
Another thing to try is to take a qtip with alcohol, unplug the computer and attempt to clean the contacts that house the dimm. If it has been in use for years there may be dust buildup.
Epox ep 8npa7i driver
seems like you won't be able to obtain drivers for this m/b from the manufacturer
http://en.wikipedia.org/wiki/EPoX
However there appear lots of places who can provide drivers - search the internet for "Epox ep 8npa7i" and take your pick - I don't know how good/reliable any of the purveyors are, nor can I recommend a source for drivers that work.
26.December.2014
