20 Most Recent Epson Stylus C43UX InkJet Printer Questions & Answers
3answers
I lost my CD for installing my printer. Can you please help me to instal my printer on my PC
You software for this printer is found at the following link. Select your OS from the dropdown box, and it will take you to the correct software
http://tech.epson.com.au/downloads/category.asp?sCategory=Inkjet&id=C43ux&EmailAdd=&CanEmail=&SelOS=Y&MetricIDReturned=2904430&sCategory1=Inkjet
12/9/2013 9:17:30 AM • Epson Stylus... • Answered on Dec 09, 2013
0answers
Epson Stylus C43UX driver
If you go to this link, http://tech.epson.co.nz/downloads/category.asp?sCategory=Inkjet&id=C43ux&SelOS=Y, you will be able to select your operating system and then download the drivers for your printer.
Regards,
Andy
5/2/2011 7:31:17 PM • Epson Stylus... • Answered on May 02, 2011
How to remove the ink
r_1.gif Make sure that the printer is on. The fontp.gif power light should be on, but not flashing. r_2.gif Open the printer cover. r_3.gif Press the fontb1.gif maintenance button. The print head moves to the black or color ink cartridge replacement position, the fontp.gif power light begins to flash, and the fontb1.gif error light begins to flash or remains on. When both cartridges are out of ink, the print head moves to the black ink cartridge replacement position first. After replacing the black cartridge, press the fontb1.gif maintenance button again to switch to the color cartridge replacement position. 98a04.gif r_4.gif Lift up the ink cartridge clamp as far as it will go. The cartridge rises partly out of the cartridge holder. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it. 98a05.gif r_5.gif Remove the new ink cartridge from its protective bag. Next, remove only the yellow tape seal from the cartridge. Do not touch the green IC chip on the side of the cartridge. 98a06.gif r_6.gif Place the ink cartridge into the ink cartridge holder, and then close the ink cartridge clamps. Do not apply excessive force to the cartridge. 98a07.gif r_7.gif Close the printer cover. r_8.gif Press the fontb1.gif maintenance button. The printer moves the print head and begins charging the ink delivery system. This process takes about thirty seconds to complete. When the ink charging process is finished, the printer returns the print head to its home position, the fontp.gif power light stops flashing and remains on, and the fontb1.gif error light goes out. 98a08.gif If you feel that my answer helped you then please give a vote for my answer.
4/4/2011 12:10:46 PM • Epson Stylus... • Answered on Apr 04, 2011
I have an epson stylus
Hi!
Go to http://support.epson.com
Hope this helps. Select Printer and click on Manuals and documentation.
4/1/2011 6:25:42 PM • Epson Stylus... • Answered on Apr 01, 2011
I lost my CD for
You can download the drivers and software from here: http://tech.epson.com.au/downloads/category.asp?sCategory=Inkjet&id=C43ux&SelOS=Y
Just select your operating system (version of windows).
Hope that helps :)
3/7/2011 2:27:40 PM • Epson Stylus... • Answered on Mar 07, 2011
Hi, I have an epson
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software , then you must connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
2/23/2011 10:26:19 AM • Epson Stylus... • Answered on Feb 23, 2011
2answers
I have lost my CD
try on this page
select your operating system and succes!
2/21/2011 7:07:08 PM • Epson Stylus... • Answered on Feb 21, 2011
I lost my installer of
2/6/2011 11:47:37 AM • Epson Stylus... • Answered on Feb 06, 2011
I want to istall my
If you have the disk ...insert it in the computer ...open it ..and choose the driver according with the operating system you use...and run it ...In the moment when it asks you to connect the printer ..do it ..and be sure the printer is powered and on ..
After finishing all the installing process ..restart the computer ..and thats all...
If you do not have the disk ...than you should download it from the support site of the manufacturer...and install it in the pc..
here is the support site..
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=21984&prodoid=33279426&infoType=Downloads&platform=All
even if the model is not th exact one ...try the 44 UX and the 42 cause there is no 43 on this site ..
http://esupport.epson-europe.com/SupportHome.aspx?lng=en-GB&data=0ccCGROWIYM58zV3pqc84W2LhUcmWnHiUk31CNK52sUU003D
12/24/2010 5:12:43 PM • Epson Stylus... • Answered on Dec 24, 2010
I lost my cs installer how can i connect it agin
download it from epson.co/support
11/6/2010 12:25:55 AM • Epson Stylus... • Answered on Nov 06, 2010
I lost its disk & can not set up
download driver from Epson.com support
11/5/2010 9:36:44 AM • Epson Stylus... • Answered on Nov 05, 2010
I performed head cleaning sevaral
clean the head is very difficult but effective use alcohol and change the pat
11/5/2010 9:32:55 AM • Epson Stylus... • Answered on Nov 05, 2010
Not head moving
u163
10/25/2010 6:10:30 PM • Epson Stylus... • Answered on Oct 25, 2010
I dont have driver to
go to this link , choose operating system . click search then continue , under driver find .exe file and click Download HTTP in blue
10/20/2010 12:14:09 AM • Epson Stylus... • Answered on Oct 20, 2010
I have a Epson printer c43ux but the CD is lost,
Go to Epsons web site, and find the support pages. Locate your model and just download the drivers for your operating system. Good luck
7/18/2010 7:30:19 AM • Epson Stylus... • Answered on Jul 18, 2010
Epson Stylus C43UX InkJet Printer Logo
Popular Tags
59 questions posted
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Stylus Epson
  • Stylus Epson
Most Popular Question
remove ink
  • Office Equipment & Supplies
