20 Most Recent
Epson LQ 580 Matrix Printer Questions & Answers
PRINTING TWO EXTRA LINE ON
Windows 7 x64 & LQ-570+ ESC/P2 @EJL solution (should also work for other printers/OS, but not tested yet):
Try modifying .dpg file.
STEP 1:
Print the windows test page.
STEP 2:
There should be written the location and name of the file (Data file), so print the test page and look up the file path. It is located in the sam folder as dll (config file). In my case it is in "C:\Windows\system32\spool\DRIVERS\x64\3\".
(Sience I coulden't find x64 driver for LQ-570+ ESC/P2 I used LQ-590+ ESC/P2 Ver 2.0 driver. It's working ... )
STEP 3:
Now, when you found .GPD file, (make backup copy just in case) you have to add your computer account to list of accounts that has full controll of file or you won't be able to save changes.
STEP 4:
Delete only @EJLl 1284.4 and @EJL in line that looks like that:
*Cmd: "<0000001B01>@EJL 1284.4<0A>@EJL
<0A1B>@<0D1B>t<011B>6<1B>R<001B>P<1B>(U<01000A>"
(If you delete anything else at that line it won't work ...)
STEP 5:
Save file an enjoy printig :P
If you have any question, write to riddle.xyz@gmail
PRINTING TWO EXTRA LINE ON @EJL 1284.4 @EJL ON EVERY FORM INVOICE AND CHECK EPSON LQ300+ RUNNING ON WINDOW 7
Thank you for tips. Starting form this I deleted the hole command line, leaving only the first "{" and the last "}" , Below is what I've deleted. Now the firs line printed is the first line in the text. If you delete only the EJL 1284.4 and @EJL, you will have two blank lines before the text you want to print.
*case: UseD4
*Command: CmdStartDoc
*Order: DOC_SETUP.1
*Cmd: "<0000001B01>@EJL 1284.4<0A>@EJL <0A1B>@<0D1B>t<011B>6<1B>R<001B>P<1B>(U<01000A>"
Printing wrong characters
Hey Kaz, do a "print preview".. this will tell you whether its the computer interpretation/rendering or its the printer...
Automatic paper adjustment
Goto File, Page Set Up, Margins.
Be sure "Marigns" is in the "Inches" setting.
Enter 3.0 inch in two boxes; Topp, & Bottom.
Good Luck,
