20 Most Recent
Epson Stylus Photo 950 InkJet Printer Questions & Answers
Epson photo 950 both ink
keep the stop or cancelled button pressed for about 10 seconds and then see. It will reset your printer and should work better again.
Take care.
When I turn the printer on, the 'on' green/yellow
well veronique I have an Epson All in One Printer and you might to read your manual and if not most like you are low on one of the ink wells in your type of printer and its easy as pie to check and change them out without a Master Degree in Computers... I simply say read your manual or go online to Epson and they have some techs whom help you gladly..............Peace
Epson printer had paper jam which is now clear but
Some paper is probbally lodged btween head and printer wall, off with the power, can you then pull head to right and seek for paper fragments smashed aginst inside wall? then if all is well may need to run a clean, you should be right...
You can download the manual for free at
www.epson.com. All you will need to do is click on the support section, select your printer model, and all available manuals will be there for you. Hope this helps & please take a moment to rate this solution. Thanks.
Ink is out and communication error has occured?
Sounds suspiciously like a Windows problem to me. It may be worth trying to reinstall the printer. Delete the old one in 'Printers', and then reload from XP or Vista, or shove the printer CD-ROM in and reinstall.
"Ink cartridges cannot be recognized" when using genuine Epson
i had this happen to me twice with two different people, it is highly possible that your black inks are defective, its also highly possible that one of the other inks are causing this error. take them all out, and put one and see what happens, do this one at a time until you see something screwey.
also possible, the contacts on the printhead are dirty or are pushed in.
also possible, bad printhead.
Epson stylus photo 950
It is not kinda solution but I can share my experience. I had it flashing all the time when I took out a cartidge.
Paper twists when feeding
there is something stuck in the feeder.place one thick paper and help it with your hant to pass into feeder.anything is inside will unstuck
