20 Most Recent
Epson Perfection 1260 Photo Flatbed Scanner Questions & Answers
I am tryingto install an
If you installed the driver then your half way there. Now with your scanner powered on plug in the cable from your scanner to your computer. A window should pop up saying a new device or driver is being installed. If it doesnt prompt you to do anything after it installs then reboot (restart) your computer. At that point you should be able to scan once the computer comes back up again.
I hope this helps you out if it does please give me a YES that I did help you. Thank you
My computer says to download
start here... pick the printer you have and download the software you need
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes
Robert
Scanning red and green over
Had the same on my Epson Perfection 1650. I was about to throw it out but decided to take a look inside. Unscrewed and took the top off (with glass bed), then unscrewed the area that houses the scanner light and a set of three mirrors, cleaned with a lens brush the mirrors although did not see any more than one spec. Put it all back together and now it works great. not sure what I fixed, but it IS fixed. may have been put together badly in the factory as this problem happened soon after purchase. I may have knock something out of place at some point. Anyway you may be lucky too!
Scanner coloring doc.
in your printer menu there should be a option for cleaning the printer heads. if not you need to remove the cartrages and clean yourself with rubbing alcohol. also clean off the cartrages also.this should get rid of the saturation problem.let me know if this helped.
Underside of document table needs cleaning
Hey! I've just find the solution. The only thing you need is a multi-screwdriver to take out the two screws sitted on the backside, then use a screwdriver with a plain point to separate the dark grey plastic piece from the light grey one (use a few toothpicks to keep every flap open). When you get all the flaps open just pull the light grey piece (the bottom one) and separate the dark one with the lid and the glass. Now you can clean conscientiounly the glass. Be sure to put in its right place the back little plastic piece that covers the power connector before closing your scanner when it's clean. Close it introducing the front side before and pressing over every flap. Work done! enjoy you Epson scanner!
I apologize for my english, maybe I've used any unconvenient word, but I think you'll understand it.
Regards,
Jordi (Terrassa, Spain)
Setting up Epsonperfection 1260 scanner.
Fredmallow,
You probably are onto the problem yourself. Try downloading drivers for Vista. If that does not work then the device is just not going to get along with Vista.
haMAR
