20 Most Recent
Epson Perfection 1650 Photo Flatbed Scanner Questions & Answers
The scanner glass inside is cloudy
I recommend you do not take off the glass. I have done it and was never able to get rid of the dust, which really shows up on every scan. The fogging has something to do with an optical coating on the underside of the glass. If I knew then what I know now, I would let it be. If the fogging doesn't show up in scans, leave it. If it really does show up, the glass itself is often held down by simple double stick tape. You try to keep the tape intact so you can put it back down. It may be strong enough that the plastic frame on top of it could snap. Do it in as clean (not dusty) environment as possible so dust does not drift down inside the scanner. Never touch the lamp or move the scan mechanism. Again, don't do it unless it's showing up on scan results. Sadly, nobody "fixes" scanners, they are disposable, like coffee pots, even if they cost 300.00.
My Epson Perfection 1650 Photo
Make sure all the scanning settings are correct first then set everything first before you preview image then hit scan.
make sure the size is correct drag the image on the prview screen make ths dotted lines frame your image then scan
remember you tell the machine what to do by setting it, if you dont the machine trys to do thevscan its self. Good luck, have fun
I have an older Epson 1650 scanner I have never
If you do not have the manual for this product, you can download it at Epson.com. Also make sure that the lamp lock has been disengaged. It's usually located under the lid or on the bottom of the scanner. This prevents damage during shipping but will give an error if it's engaged when you warm it up. Good luck.
Do I need to uninstall
No, you don't. If you are worried about it, you could uninstall, reboot Windows, and reinstall.
My scanner perfection 1650 won't install to vista
Some people get this part confused, their is the chose operating system and then theirs chose the os version, you probably have a 64 bit o/s from the issues you are claiming. the fix here is you need 64 bit drivers. their is no official fix, but this will and probably mostlikly is the fix, a revemped or moded driver that works with your make and model scanner,
http://www.planetamd64.com/lofiversion/index.php?t30749.html
this is for TWAIN 5 support as well nothing but posative ratings, id get it soon cause rapidshare will closr the link after a given number of days passed.
Direct link to driver
http://rapidshare.com/files/82757175/EPSON_PERFECTION_1650_VISTA_x64_DRIVER_-_US_ONLY.rarthanks for using fixya.
