20 Most Recent
Epson Perfection 2400 Photo Flatbed Scanner Questions & Answers
Makes clicking sound
Does it make the noise even when disconnected from the computer? Try to unplug it from the computer but leave the power connected (if it is a model with separate power and data connection) and see if it still makes the noise.
If it does then it is a hardware problem and it will need repairs. If it doesn't then its something in your software attempting to talk to the scanner incorrectly. You can try reinstalling the software for the scanner to ultimately test.
Cloudy glass inside scanner
you have a damp room, you need to put a sachet in the scanner the ones you get with new shoes or electrical devices in the packaging. this will clear up the scanner also have one in the room you can buy tubs that remove water vapor from the room .
After I scan text, I cannot put it into a Word
In order to scan to word so a document is editable you need to use Optical Character Recognition Software (OCR). You can download free ocr software from www.simpleocr.com Use that software and then either export once scanned to Word or Save as a Word document in the OCR application.
I have a paper copy
Once its printed or sent to the scanner , I don't think you can edit. Im pretty sure you can only do the editing direct on the PC
Epson perfection 2400 photo scanner stuck with flashing red light
You may have accidently pushed the LOCK button - this button is used to LOCK the carriage into place when moving the scanner to another location or shipping it.
Check for a button and the picture of a LOCK, it is usually at the back of the scanner, you can push it left or right, and you have an open lock and a closed lock picture under it. Make sure you didn't accidently push it to the LOCK position when holding the scanner - that loud sound means your carriage is locked and cannot move - once you set the button to UNLOCK this should solve your problem.
I have not used the
Hi.
Yes, when you choose start Scan in the software, the light will come on and move across the document to perform the scan job.
You will probably need to install again the scanner software and driver.
Please click here and download the software. With windows you need to download TWAIN DRIVER AND EPSON SCAN UTILITY.
Once download is complete, install the software running the downloaded file. You may need to restart the computer after installing. Ensure that you authorize any system change if required by Windows or by security software.
I can not open my scanner epson perfection 2400
Sounds like there is a problem with the driver. It is more than likely a software problem on your computer.Did you install a software disk for it? Was the error message on the scanner itself or on the computer? Your best bet might be to uninstall the software and then reinstall the software, but that is all I can tell you with the limited information you gave.
Everytime I try to use the scanner it says an
Pop over to the epson support page and download your drivers.
I HATE scanners when they start to act up, printers are sooooooooo easy, but scanner/twain problems arrrrrggggggggggggggggggg
Good luck
Perfection 2400 scanner fails to scan; just clicks
The only thing that usually causes a scanner error of this type is either a scanner failure or the transport lock. Locate the lock and make sure it is in the unlocked position. Lock and unlock a few times leaving it in the unlocked position then power the scanner off and on again.
File Names Limited To 7 Characters
Suggestion:
First update your PC to Windows XP service pack 3 and then update all patches after that. The problem will most likely still exist as this limit was an old MS DOS limitation so I'm leaning as the root cause of the problem lies with the Epson Software. After XP is fully updated and patched try the Scanner again. If still limited - uninstall and reinstall the scanner software.
Keep me posted.
I have a 2580 Epson Scanner and for some reason
hi there, it may be that Epson hasn't developed drivers compatible with your system. My suggestion is to try it on another computer that has windows and see if it works. If so, go on Safari and type in Epson Perfection 2400 Photo Flatbed scanner drivers and see what comes up on Epson's website.
