20 Most Recent
Fujitsu Pocket Loox 410 Pocket PC Questions & Answers
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
HOW TO RESET THE BIOS PASSWOrD FOR FUJITSU LH532
THERE ARE 3 LEVELS STATED IN THIS 2012 MANUAL BIOS.
SUPERVISOR (ADMIN)
USER
AND BOOT PW.
1,2,3 Three kinds/
and 2012 PC is w8 ready meaning the old COIN pulled way is now useless, as the manual told you, page 10
if ADMIN is set , bios screens are locked out. on purpose
boot pass word blocks windows from booting. not entered correctly.
if TPM was set the PC is locked out, hard. by design.
TPM set and then cleared using ADMIN login, all data is lost. gone
by DESIGN TPM rules and laws there of.
we can;'t see what is set in your bios. so....
now level 4, HDD security page12 if set that too is locked out.
we can't see any of this in a text box.
if you bought it locked out send it back
if from a friend as a handme down, ask them for the PW.
or guess.
or google backdoor passwords
FUJITSU LH532
page 10 says (see photo and learn this)
https://www.manualslib.com/manual/829337/Fujitsu-Lifebook-Ah532.html?page=10&term=reset&selected=2#manual
see the will not word,
that means ONLY HACKING works and we are not hackya dot com.
google for hacks if you want.
all PC laptops 2012 and newer the rules are strict.
next time don't set this junk. or write it down next time.
6/18/2022 3:13:13 PM •
Fujitsu...
Answered
on Jun 18, 2022
Boots up on the 4th time (?)
Fujitsu , now that is a rare PC, 2007 MADE,
15 YEARS OLD TODAY, not good that.
intel Celeron M 550 1 x 2 GHz, Merom ERA.
Graphics adapter" HORROR !
SIS Mirage 3+ 672MX
SIS is a dead maker of chips now and A huge PROBLEM.
OS = VISTA
THE LOWEST RATED PC ON EARTH THEY SAY.
no matter what OS you try , no OS on earth runs on bad hardware
if you run tests correctly you'd see
- huge battery no good, remove it run on AC power , even forever.
- RTC CMOS coin cell is bad, not one ever lasted 15 years. .
- replace that COIN BAT. now and can not be ignored.
- next is hdd bad, run smart tests on it,and it will fail as no OS on earth ever runs on any bad HDD. never. ASK HOW.
- last is , CCFL back lamps will go dead , and means zero future for this PC but by magic yours work, (a kinda trap that).
- The SIS chips have zero support but for VISTA from OEM direct but Fujitsu ended support long long ago. ask Linux folks for help finding relic SIS GPU support, good luck there, now.
- It came new in the box NIB with Include Knoppix4 Linux CD !
- Siemens dropped out so only Fujitsu remains if at all.
I see one hit
https://forum.ts.fujitsu.com/forum/viewtopic.php?p=139199
the folks there burned the ISO wrong.
or do no know how to use boot order in BIOS.
it must result with CD full of files. or was done wrong.!!!
diagnostics. on CD (iso) ask how to burn ISO it's easy .
learn too that if PC is super bad, hardware even DIAG fails.
most these PC are in the land fill now, (15 years old and dead)
RIP
2/13/2022 11:10:59 AM •
Fujitsu...
Answered
on Feb 13, 2022
Fujitsu Siemens Esprimo E5905
16 year old PC (2006) pure junk now. .DO NOT UPDATE FIRMWARE BIOS or did you mean this. OR DID "UNABLE TO UPDAT"E BIOS MEAN I CAN NOT SAVE SETTINGS IN BIOS. and bios dates are wrong too. ANSWER , RTC CMOS COIN CELL is DEAD. sure it is , not one lasted 16 years ever so this is legacy PC sold in garage sale for $1??????
https://support.ts.fujitsu.com/indexdown... leave BIOS firmware code alone or brick this PC you will, BIOS code in EEPROM does not leak out like rusty old bucket of water. the battery is bad. support ended
https://support.ts.fujitsu.com/IndexProd... seen here as proof.
2/12/2022 1:28:27 PM •
Fujitsu...
Answered
on Feb 12, 2022
