20 Most Recent
Fujitsu AMILO D-7820 Notebook Questions & Answers
I want lan card driver
buying a lan card is costly..........u can hav the same adv by buying a modem of bsnl which has lan and wifi for the same rate which is usb connected to the comp
Restoring to factory settings
to restore the factory setting you must boot the laptop off of the restore CD it will wipe the drive and reinstall the factory software and drivers just walk through the prompts. holding the f8 key will not restore the laptop to factory settings it just allows for options during windows startup
Reset bios motherboard
RTM - Read The Manual.Get onlineand got to www.google.com In the google search box type: "FujitsuSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals. Search the manual for bios or bios password.
Pls i need to listen
I know how inconvenience it is for you. Laptop could not be as useful and fun without sounds.
But don't worry I will help you to get a audio driver for free online, in fact I have a link for you to visit so that you can download a free audio driver.
Please just click the link:
Audio_Driver. Once you get on the exact site you will see a link that says "Free download" just click on it, then follow the prompts. Then you are good to go.
I hope you find it very helpful.
Thank you for using fixya.
Fujitsu siemens d 7820 i
If it is the graphic's driver that is missing, you can go to the
Fujitsu Support > Downloads page to obtain the latest drivers for Windows XP.
- Go to http://ts.fujitsu.com/support/downloads.html
- In the 'Product Search by Serial-/Identnumber' searc box, type AMILO D7820.
- Once the page opens, verify that 'Windows XP' appears under 'Selected Operating System'.
- In the list which appears, click on the '+' near graphics.
- Select the version of the driver you want and click on the download link.
Really hope this helps you.
After installing windows 7 ultimate
Is there a switch on the side of the laptop? Turn it on if there is one. Are the proper drivers installed? Go into the Device manager (press the windows flag + pause/break, then click device manager). Find the Network adapters. Is your Wi-Fi listed?
- Mark
I cant find sound card
Please go here:
http://webdownload.ts.fujitsu.com/download/FileDownload/fileDownload.aspx?SoftwareGUID=57FADAEE-9894-432E-BEFB-76DCF2B392B2&FileFolder=Downloadfiles&FileTypeExtension=ZIP&FileNameClient=FTS_SoundSiS7012AudioDriver__1001996.ZIP&FileSize=8067294&From=XV1db2trUHNzb15eTExoZW1vWygm
and Check I agree then click Download Button.
Regards,
Katharsys
Plz i need the audio
Visit the Manufacturers website
Navigate to Downloads and Drivers (may be under support tab)
Choose the Model of computer you are using
Choose the Operating system you are using
Select the Driver you need
Download
Install it
