20 Most Recent
Samsung LN46C630 46" Series 6 LCD 1080p HDTV 120Hz Questions & Answers
One side of my tv gets dim and out of focus it is a samsung. At times it works fine
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
How do I troubleshoot my Samsung TV?
I have sound, but no picture.
Caps can fail with no outward signs. It takes a special meter to test them. Your set may have a back light inverter that powers the back lights. When it fails, the picture cant be seen, but you have sound, to check this look for a picture on the screen using a flashlight
My Samsung Tv modle LN46C600F3F has sound no picture, what could be wrong?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Increase brightness in samsung tv
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Why dont i have a picture?
Hi, not sure if you have the same fault as i had, but our tv only had half the screen go off, after looking up on the internet i found a video for a fix, what you need to do is remove the back cover, there will be ribbons that go from the front screen to the main panel, i removed each one at a time and rubbed the contacts of the ribbon with a rubber on the end of a pencil, plugged them all back in and switched it on and it was now spot on, thats more than a year ago and its still working spot on, hope this helps
jim
Too bright/high contrast, unable to adjust. Tried to adjust from MODE: DYNAMIC, STANDARD, MOVIE=NOTHING, Tried-Background, Contrast, Brightness, Color, Tint, Gamma, Picture Factory Reset=nothing.
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
http://electronicshelponline.blogspot.com/ .In most cases, the main board might have to be replaced.If so, a software [firmware] update too might be necessary.
