20 Most Recent
Samsung UN55ES6500 55 Inch 3D 1080p Smart TV LED LCD HDTV Questions & Answers
I have lost reception on channel 9 and pixels playing up on other channels how can I fix the problem Samsung smart tv
Do a reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
9/12/2016 9:59:47 AM •
Samsung...
Answered
on Sep 12, 2016
How do I make the sound sinc with picture after I've connected to sound bar
I have a 60 in. Vizio, but I'm pretty sure this will help you out: With the remote that came with your TV (not TiVo, ScientificAtlanta or some other device programmed to control it), press the menu button, then click on audio. You should then see a choice that says "lip synch" or something like it. Click on that and a bar graphic should appear on the screen that looks something like this:
_ __________________ +. This allows you two synchronize and set the audio with the picture - either slow it down or speed it up by a few seconds either way by using the TV remote. I've never had to use it with my Samsung HT, but I know it's there and I know it's function. My TV is also a smart tv, so this should work for you. Good luck. . .
5/14/2016 4:50:21 PM •
Samsung...
Answered
on May 14, 2016
How to fix a samsung 55" led tv with screen half dark and solarized colar
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ....
5/10/2016 1:15:42 AM •
Samsung...
Answered
on May 10, 2016
Screen has weird color and refresh rate is very slow
4/14/2016 10:07:50 PM •
Samsung...
Answered
on Apr 14, 2016
The Samsung app is not in my list of apps, what do I do?
You can search for the apk, "Samsung App Store apk"
You can check my link, there is another link within it that may still be valid.
the important thing when searching for this apk is try and download it from a place that you can trust,
you may need to change the setting in your phone that allows you to install applications from unknown sources.
Good luck and thanks
Questions? Just ask!
11/27/2015 4:50:47 AM •
Samsung...
Answered
on Nov 27, 2015
Why is top third of screen darker than bottom two-thirds?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
10/17/2015 3:41:13 AM •
Samsung...
Answered
on Oct 17, 2015
1.5 yr old Samsung series 6 6030 will not turn on
Sounds like main board fault. But, before make it confirm, try a hard reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
9/8/2015 5:22:35 PM •
Samsung...
Answered
on Sep 08, 2015
No picture and no sound
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
8/26/2015 8:08:22 AM •
Samsung...
Answered
on Aug 26, 2015
