20 Most Recent Samsung 32" Class Full HD 1080p 60Hz LED-LCD Smart TV UN32EH5300F Questions & Answers
Samsung un32eh5300fxza tv has no picture. Has sound and if you use a flashlight you can see the picture.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
11/19/2015 10:31:06 AM • Samsung 32"... • Answered on Nov 19, 2015
How to use tv as computer monitor
A lot will depend on what computer you have. If your computer has got an HDMI output then you can connect this port to the HDMI input of the TV using an HDMI cable. Then in windows control panel of computer you select Display properties and select the monitor port.
8/18/2014 1:59:29 AM • Samsung 32"... • Answered on Aug 18, 2014
I WANT PASSWORD TV SHOWNIC TYPE LD-F42HS90 PLASE
2590,220184839
8/17/2016 2:53:29 AM • Samsung LE... • Answered on Aug 17, 2016
0answers
Le32b530
Be the first to answer 8/29/2015 10:47:23 PM • Samsung LE... • Posted on Aug 29, 2015Be the first to answer
Samsung le26a6 will not switch on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
3/11/2015 1:46:13 PM • Samsung LE... • Answered on Mar 11, 2015
Television keeps clicking like it wants to turn on but doesn't come on. will come on ocassionally after a long wait
you will need to replace the leaky capacitors in the power supply circuit. You can locate the faulty capacitors with a visual check. Those that are bulging need to be replaced.
3/4/2015 7:33:18 AM • Samsung LE... • Answered on Mar 04, 2015
My tv has sound but the picture is white. Unable ti see the screen. Can see shadows. What is wrong with it? It's a samsung lcd
i need the model,but the problem is in the T-con board.
1/27/2015 5:34:52 PM • Samsung LE... • Answered on Jan 27, 2015
0answers
0answers
How to repair
Be the first to answer 8/17/2014 8:46:26 PM • Samsung LE... • Posted on Aug 17, 2014Be the first to answer
Samsung 46 inch keeps turning on and off immediately by itself
Most likely the power supply capacitors. you can identify them by their bulging tops.
7/24/2014 6:56:12 PM • Samsung LE... • Answered on Jul 24, 2014
0answers
0answers
0answers
0answers
LE40A676 t-con
Be the first to answer 5/23/2014 9:17:40 PM • Samsung LE... • Posted on May 23, 2014Be the first to answer
Samsung 32" Class Full HD 1080p 60Hz LED-LCD Smart TV UN32EH5300F Logo
4 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LE Samsung
  • LE Samsung
Most Popular Question
samsung un32eh5300fxza tv no picture
  • Televison & Video
