20 Most Recent
Lorex SG-7964 VHS VCR Questions & Answers
I need a belt for the drive system....
Not heard of this maker before, so all I can suggest is you measure the diameter of the belt, plus it's width (in mm), you need also to note if it is one of those belts that is for cogs or just a standard rubber band type.
Belts are pretty standard and are not maker specific, so if you see one that is about the same size it should fit. The best place to get one is CPC online parts place.
Time Lapse Recorder TLR-1281
Hi, Lucky for you there are only 1 set of audio in/out and video in/out so this is not difficult. If you want to hook to a monitor or tv use a standard set of RCA audio cables one connector on each end is white the other is red. The video output is a BNC male connector which you can easily adapt to an F connector which is the standard coaxial input you find on any tv or monitor. You can find this adapter to fit directly onto the BNC connectors and then use any standard tv cable. The same with the video in. The adapter is BNC female on one end to male F on the other end. You need 2. If you need any more help please ask but this should Fixya!
Lorex LHV1000 HD DVR. I have one that does not want to boot. Power turns on, fan is working, but HDD light doesn't blink and nothing is coming on the screen. Power button doesn't seem to work.
If your Lorex LHV1000 HD DVR is not booting up, there are a few things you can try:
- Check all cables and connections: Ensure that all cables are securely connected to the DVR and that there are no loose connections or damaged cables.
- Restart the DVR: Disconnect the power cable from the DVR, wait for a few minutes, and then reconnect it. Try to power on the DVR again.
- Reset the DVR: If restarting the DVR doesn't work, try resetting it to its default settings. This can be done by pressing and holding the reset button on the back of the DVR for about 10 seconds.
- Check the hard drive: If the DVR is still not booting up, it could be due to a faulty hard drive. Try removing the hard drive and connecting it to a computer to check if it's still functioning properly.
If none of these steps resolve the issue, it may be necessary to contact Lorex technical support for further assistance.
No hdd detected
You will need to contact your Service provider and get the unit replaced. Your HDD may be broken in your DVR.
