20 Most Recent Sharp LC-42D72U 42 Flat Panel 1080p 1920X1080 HDTV LCD TV Questions & Answers
Our sharp tv model # LC-42D72U power light flashes green but there is no sound or picture. Looking for your expert opinion on what could be wrong so we can get the part ordered.
Green on light is blinking, but no picture - Television - iFixit
https://www.ifixit.com/.../Green+on+light+is+blinking,+but+no+pict.. iFixitOct 3, 2014 - The Sharp LCD TV LC37SB24U set worked until off button on remote ...The green light is blinking any time power cord is plugged into the wall outlet. ... It does sound like either a bad inverter board or a bad power supply. .... On the clad sidethere is no connections or ribbons that indicate hard current draw ...
11/15/2017 8:19:15 PM • Sharp LC-42D72U... • Answered on Nov 15, 2017
How do get full screen on LC-15S2u
Menu on remote and make sure you have it on wide screen or 16 to 9
1/17/2019 10:35:18 PM • Sharp LC... • Answered on Jan 17, 2019
Why isnt roku 3 working through my LC-32DV24U roku 1 worked fine
Hello If your Roku 3 player is not connecting to WiFi, it is possible that the WiFi signal from the router is out of range. In order to strengthen the signal, move the router and Roku 3 so that there are fewer objects and walls between them. For any help or support just visit us: www Roku Com Link
5/26/2018 8:22:34 AM • Sharp LC... • Answered on May 26, 2018
When I connect my wd box to my tv it blacks out every 10 secs very annoying when watching a movie. This doesn't happen when we watch a dvd. When we watch regular cable we see a blue box appears on t
When you say WD box, do you mean a Western Digital Hard Disk Drive? If so, get a Solid State Drive (SSD), and connect it via USB3. The HDD or the USB connection is not fast enough to keep up with the required speed of the video. If you mean something else, please add details.
12/5/2017 9:28:46 PM • Sharp LC... • Answered on Dec 05, 2017
I have a Sharp LCD TV Model # LC 32SB220U. When you turn the power on, within a minute or two, it clicks off. I have tried everything in the instructions to troubleshoot the problem. I also reset to f
Check the high voltage circuit on the board that has the 120 volts input. The high voltage should be close to 400 volts - nothing less than 390 volts. The capacitor is failing to hold the voltage and needs to be replaced.
10/29/2017 1:23:31 AM • Sharp LC... • Answered on Oct 29, 2017
I have an LC-32D33X sharp tv... it just turned off on me :( and now the OPC and the power lights on the tv are flashing SOS style :(
un plug tv and try to force on by pressing vol_ and input button from tv then plug back in see if tv comes on .
12/16/2016 9:30:47 AM • Sharp LC... • Answered on Dec 16, 2016
How do I find out the year my Sharp Aquos TV was manufactured?
Look for it at its bottom side [stand]
9/26/2016 6:46:48 AM • Sharp LC... • Answered on Sep 26, 2016
Instruction manual for Sharp Roku tv LC-32LB481C
Hi, Here you can get solution of your question/problem. https://support.roku.com/hc/en-ca/articles/209403268-Roku-TV-Introduction
9/17/2016 4:39:52 PM • Sharp LC... • Answered on Sep 17, 2016
Will the tv stand of sharp lc-32 sb-24u fit on the sharp lc-32 g4u
TV Parts Universal TV Stands DLP Chips ShopJimmy You can get a universal stand from here.
9/12/2016 4:24:30 AM • Sharp LC... • Answered on Sep 12, 2016
Is there bluetooth on sharp tv ?
Not on every model.
9/12/2016 4:19:32 AM • Sharp LC... • Answered on Sep 12, 2016
2answers
My Aquos 70 tV does not turn off
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
9/6/2016 4:48:15 AM • Sharp LC... • Answered on Sep 06, 2016
Sharp LC-42D72U 42 Flat Panel 1080p 1920X1080 HDTV LCD TV Logo
1 questions posted
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LC Sharp
  • LC Sharp
Most Popular Question
our sharp tv model lc 42d72u power
  • Televison & Video
