20 Most Recent
Fujitsu Siemens LifeBook E8010 Notebook Questions & Answers
Hey I have a student
The quickest way is to reboot the machine, sounds like someone held the shift key down and has got locked into sticky keys.
I have life book E
the Operating System is faulty..
Reload the Operating system and your laptop will be back to life...
Enjoy..
I forgot the bios password
The simplest way to remove a BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
Anyway, open up the computer case using a screw driver and locate the flat, circular and metallic CMOS battery. It should look something like the picture to the right. Some computers have this part standing upright.
Once you have located it, observe how the latches are holding it. There are many different ways to remove a CMOS battery but the most common way on newer computers can be seen in the picture below.
Make sure to power down the computer, unplug the power cables and unplug any USB devices if they are powered. The computer must not be able to get power from anywhere for this to work. Take out the CMOS battery and wait 10 – 25 minutes before putting it back in. The reason for this wait is because the computer can still store power in its capacitors even though everything is unplugged. The waiting period allows enough time for them to discharge.
Plug everything back in, power up the computer and enter the BIOS again. If everything went well there should be no more password. In some cases, if you get weird error messages during bootup now, you will need to goto “Load BIOS Defaults” in BIOS and save the changes to fix them.
And Thanks.
Forgotten bios password
It is bios password.
Now if you forgot it then you have reset your bios settings.
For that you have to open back cover of laptop.
Then find motherbord pull CMOS cell from motherbord for 10 minutes then put again to it's position.
Then it not ask for password.
Let me know if you need more assistance.
Thanks.
My power connection keeps on cutting out and has
sounds like your cable connection or the laptop connection is worn out. or oxydised. a fancy way of saying you need to clean up the metal connections. is a fine sandpaper to clean the surfaces. check the parts are not loose and rub a soft carbon pencil over its surface to leave carbon dust on it. carbon is a good conductor so ensure your not causing a short circuit.
if it is a loose connection, look carefully to see if the female part is a folded metal part that can be slightly bent out of true, allowing a tighter fit.
AndystUK
My laptop screen needs a new ribbon
Hi there :)
After I did some research for you and for the part you mentioned I found that RogerHenson can be very helpful. You will be required to send him a detailed email with the laptop info (serial number, model number brand , year of manufacture etc). Tell him which part you require and he will be able to send it to you via courier within a short time :) Here is the email
[email protected] he is very helpful for sourcing out hard to find laptop parts :)
It was nice helping you :) and hope you wll be up and running soon :)
Best Regards
How to format a install windows xp3 on FUJITSU SIEMENS
backup your data first in any external source. insert bootable cd of xp and boot from it. follow the instruction and finish the installation after that install required drivers and apps.
in starting you need to select boot from cd., can be select-able from bios and also by pressing f12.
My power button is not working, is their any way to start the nootebook making a power shortcut?
If the laptop was opened up, (ALL power removed -> AC adapter and battery; PLUS -> anti-static precautions taken!), and the laptop has a power on switch, (under the power on button), that plugs into the motherboard; you can unplug the switch, and touch the motherboard contacts to try to turn the laptop on. (Sorry about the run-on sentence) Jump a wire or similar, across the contacts, and see if the laptop turns on. Could try to be more specific, and detailed, if you had listed more info about the Fujitsu Lifebook. Such as it's Series number and Model Number. Example: Fujitsu Lifebook E8210. In this example E is the Series number, and 8210 is the Model Number. Post back in a Comment.
Regards,
joecoolvette
